Deandome -> RE: Good Higher performance steering servo for Maxx (3/30/2004 6:42 PM)
I THINK the 5645 will be better. I know it's digital, has bearings, metal gears, great specs. It's NOT just a digital version of the 645. I got the 5945, which is the same as yours with a coreless motor, but I only did so 'cause I got it at a great price from a seller here on the RCU Marketplace (plug-plug!!). What does digital mean? Not that you ask, and more importantly, I don't really know, so I'm hoping someone can help explain it. I don't think you need it for basic higher-end radio functions (endpoint setting, anti-lock, etc,) but I do think you need them for the "HSR" radios (high-speed response), and you actually need a special programmer to take full advantage of them. I guess you can set them to work like a fail-safe, where the servo actuates to a preset position if you go outta range. Like I said, I think a lot of us would like to know what "digital" really brings to the table re. servos, so please chime in!!
