dionysusbacchus
ND, USA Status: offline
quote:
Do you have any photo's of that Aileron taken from the top? I bet you don't see much if any gap as it looks like there is some overlap of the top sheeting past the TE much like we do it with 1/64 ply on our models. Found some photos of this in Detail& Scale pg 43 Glad to have you back with another good thread. Hi Pete, I've been looking at Corsair ailerons for a while now! Like I said in post #66, I'll close the gap with 1/64 ply after the flaps are cut and hinged. The gap I was talking about was at the bottom, mine are tight, much tighter than the full scale looking at the pictures. But with the gap filled at the top I guess it won't matter. I have the same book, it's a must have. The drawings suck but the pictures are very nice. Thanks Pete, glad you like the F2G thread! quote:
I read somewhere that at low speed (landing) the drag stays high but the ailerons lose effectiveness so the yaw effect get's exagerated and pulls the model the opposite way to what the pilot intends. I guess though that the pilot should be using rudder then anyway. Hey Brian, Yes, if you use ailerons on your final landing approach then you are doing a bad, bad thing! I'm sure they will do fine though. I'm sure Vought would have done something different if they didn't work! Dion
