RE: F2G Corsair Build Sneak Peak!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: F2G Corsair Build Sneak Peak!!!
Page: <<   < prev  1 2 3 4 5 [6] 7 8 9 10   next >   >>
Login
RE: F2G Corsair Build Sneak Peak!!! - 7/15/2004 4:18:46 AM
dionysusbacchus
Status: offline
quote:
As usual nicely done. Well I started to work on my TF Corsair again after giving up on Sierra retracts and working on other projects. Keep motivating us
Thanks Pete, that's great news you are starting on the Corsair again! Keep it going!
quote:
I'm surprised that you built the canopy form almost "free-hand". It's really looking good. I usually do this work with the side profile and formers.
Hey Flo, Surprised? I never do anything the easy way, it's against my principals! I prefer working free-hand, having all kinds of formers or rules hinders me! I like to use my eye to judge things, although it don't always work!
quote:
Luke can build anything with a little spit and bubblegum! NICE canopy, dude! I'm gonna need one of those when I get around to my Race #57
Haha, you kill me Glory! Don't know about the bubble gum thing! You will get a canopy, and I want a plane built for it too!!!
OK, back to the build! Didn’t get my clear plastic sheet, UPS man missed delivery, won’t be here till tomorrow. Had a whole day to work on the F2G, so I had to do something!
1. I installed all the snakes needed for the controls, retract and steering. With that done I needed a canopy to finish the top sheeting, so I made one out of ABS for now. I order 8’ sheets of .040 and .020 ABS so using it up is not a worry!
2. Shows the new former F-8B that I had to add to support the rear cockpit deck. I’m making the canopy operable so I wanted to get this area as close to right as I could.
3. Rear deck installed.
4.Here I am tracing the outline of my canopy and checking the fit.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by dionysusbacchus -- 7/15/2004 9:23:03 AM >
(in reply to Glorystomper)
       Post #: 126
RE: F2G Corsair Build Sneak Peak!!! - 7/15/2004 4:21:12 AM
dionysusbacchus
Status: offline
1.The rear turtle deck can be easily sheeted with 2 strips of balsa. Glue the front down first then trim the last little bit in the rear and glue it down. The fuselage is in very rough shape, after the bottom is sheeted I will then start to sculpt and carve it into that sexy shape!
2.Just to see how it will look! I will get my plastic tomorrow, so I’ll be busy again making parts on the vacuum former.
Dion
Click for fullsize
Click for fullsize
(in reply to dionysusbacchus)
       Post #: 127
RE: F2G Corsair Build Sneak Peak!!! - 7/15/2004 8:38:11 AM
Florian Kuehni
Status: offline
spit and bubblegum... hmmm....
What about cockpit interior? are you going to build a scale cockpit into this Corsair as well? Looking at the pics, it sems that the cockpit floor is fairly high...
Just thoughts and questions
Flo
_____________________________
my harddeck is at 1ft below ground level
       Post #: 128
RE: F2G Corsair Build Sneak Peak!!! - 7/15/2004 11:03:24 AM
dionysusbacchus
Status: offline
quote:
ORIGINAL: Florian Kuehni
Great, I like thoughts and questions, keeps it interesting! The cockpit floor is at the scale height, and yes I am going to add the cockpit interior. This is a good time to add some great pictures, I've been saving these! Notice that the pilot is sitting on the floor basically and that the seat cushion is at the top of the left and right consoles. Then look at the distance from the top of the consoles to the top cockpit side, not that deep is it? The fact that the rear turtle deck is cut down is adding to the optical illusion that you are seeing. The cockpit is really very shallow.
Dion
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by dionysusbacchus -- 7/15/2004 6:10:28 AM >
(in reply to Florian Kuehni)
       Post #: 129
RE: F2G Corsair Build Sneak Peak!!! - 7/15/2004 10:15:53 PM
YAT-28E
Status: offline
Dion,
Looks like race #57 cockpit ...... is it not?
Did you have time to talk to Bob O?
I have being doing so much, with so little for so long...that now I can do anything with nothing.....G. Ivory
       Post #: 130
RE: F2G Corsair Build Sneak Peak!!! - 7/16/2004 3:11:01 AM
dionysusbacchus
Status: offline
quote:
ORIGINAL: YAT-28E
Dion,
Hey babysitter! Have I been good? Yes it's race #57, I had someone take them for me, I've never seen it in person. They would have had a hard time getting me off of it with my tape measure! Can I play now?
OK, now for the fun… yea that’s it! Let me just say that vacuum forming white styrene is nothing, trying to get a perfectly clear canopy… now that’s something! You da man if you do’s that! I have formed clear parts in the past, but all were for small fun scale junk, I scratch built a couple of fun scale Mark’s Models Corsairs and I made the canopies for them. I didn’t care about how they looked though! I’m still working on the technique for this but I am getting close to perfection!
First off plaster plugs will never give good results on clear parts, it works great for White Styrene though. I took some .015 Styrene and formed it over my plaster plug , I then hit it with some 600 grit sandpaper to make sure it was smooth.. Then wipe it down with a tack cloth. No matter what you do stuff will stick to the plastic sheet, pulling the protective plastic off the sheet will cause static electricity!
I got the aluminum frame idea from Chad Viech, thank you Chad! I was using wood before, big pain. Using aluminum makes it so easy. I probably made my frame to big, it’s 24” long and it rests on the stock rack stations on the side. I have to use some sheet metal screws on the end of the frame to hold the plastic. The one problem with a frame this size is that the heating element is not that long, so the plastic only gets soft in the middle.
Here it is after forming.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to YAT-28E)
       Post #: 131
RE: F2G Corsair Build Sneak Peak!!! - 7/16/2004 3:12:40 AM
dionysusbacchus
Status: offline
And it pops right off! Now start looking for the smallest of flaws… darn I see a speck right in the clear area!!!!!
Here is my production line, why I kept making them I don’t know! Was having to much fun trying to make the perfect canopy maybe?
Dion
Click for fullsize
Click for fullsize
       Post #: 132
RE: F2G Corsair Build Sneak Peak!!! - 7/16/2004 10:20:12 AM
SBR_RV
Status: offline
wow, i can just tell this will finish out to be one of the best looling corsairs i've seen, and as for all the pics of real corsairs, your realy lucky, ive never seen one in real life.
that tail wheel work is great.
       Post #: 133
RE: F2G Corsair Build Sneak Peak!!! - 7/16/2004 10:42:35 AM
Glorystomper
Status: offline
Luke, I *really* think that the title of this thread is WRONG. It's WAY off.
It should be called..
PORNO FOR PILOTS.
Cuz y'know.. like.. these pics that yer posting.. uh. I think I need another tissue.
You can make anything fly if you put a big enough engine in it... umm, right?
(in reply to SBR_RV)
       Post #: 134
RE: F2G Corsair Build Sneak Peak!!! - 7/16/2004 2:47:02 PM
RickVB
Status: offline
Re: Glory's posting
Gees, you sure can tell this is a male dominated hobby...
Rick Vera-Burgos
Novi, Michigan
       Post #: 135
RE: F2G Corsair Build Sneak Peak!!! - 7/26/2004 4:51:56 PM
dionysusbacchus
Status: offline
quote:
ORIGINAL: IL2rv-56
Thanks IL2rv-56! I'm glad you are enjoying my thread.
Glory!! Haha, I'll keep that in mind for my next giant scale Corsair thread if I do one!
OK, I have not been working on my project for almost 2 weeks, I have been working on planes though! I am out of town, well... way out of town! I'm in Bellingham Washington, I'll be here one more day then I'll fly back to FL. The plane I got to work on is Bill Anders Skyraider, they are deFrenching it, taking off all the old French antenna and things. It will be painted in the Vietnam camouflage later. I also got to crawl all over his F8F-2 Bearcat, by the way the Bearcat is for sale for $$$2.3 Million if anyone is interested! I am thinking of driving to Seattle tomorrow to see the F2G at the Museum of Flight, not sure if it will be worth it though, you can't get near the thing with all the alarms and cameras around it, really a shame.
See you all later,
Dion
Click for fullsize
Click for fullsize
       Post #: 136
RE: F2G Corsair Build Sneak Peak!!! - 7/27/2004 1:33:59 AM
John Rood
Status: offline
Some while ago, some famous guy said:
"Health is more valuable than wealth"
Hippocrates(460-377 B.C.)
But not long ago, Dionysus-Bacchus intoned:
...by the way the Bearcat is for sale for $$$2.3 Million if anyone is interested!
And, yeah, OK, on a different note, Dionysus-Bacchus said:
"...The plane I got to work on is Bill Anders Skyraider..."
Well, all I can say is the big ol' "ABLE DOG" even makes LUKE look small !!!
Hehe... have a great trip back, Luke-Baccha-Hoovius. Me, I've had to be away again myself, etc., etc.; but here at home in Boston I have finally gotten started on my Corsair and I am psyched. More on her tomorrow.
Meanwhile, because of the Democratic National Convention we have had solitary F-15 Eagles circling us aloft, exactly as they did on 9/11 and the days following. I cannot describe what it looks, sounds, and feels for me to see this solitary bird aloft as a last line of defense against catastrophe. These are amazing times...to my knowledge we've never had aircraft doing CAP during public events here in Boston!
Have a great trip back, Amigo. Thanks for your cool post today!
John
       Post #: 137
RE: F2G Corsair Build Sneak Peak!!! - 8/2/2004 3:53:40 PM
dbrown2020
Status: offline
Uncle Luke,
Looking forward to seeing you put this bad boy in the air!! I'm keeping an eye on your progress. I'm interested in seeing what Magyver (sp) technique you come up with next!!
Devin
(in reply to John Rood)
    &n
