RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! Page: <<   < prev  15 16 17 18 19 20 21 22 23 [24]
Login
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 9/5/2010 9:15 PM
TigerI
Score: 100
Last Login: 12/28/2011
Status: offline
I just bought the Stanley Fat Max tool box for my field equipment. Can't decide on using a deep cycle marine battery or a jumpstarter for charing my LiPo batteries( 3S 4000mah & some 5S 5000mah). The weight of the marine battery worries me as far as the box holding up to constant use. Are jumpstarters sufficient for what I want to charge. I know they are only 18-22Ahr but they weigh less & have built in charger to replenish the battery & the marine battery would probably be 50-75Ahr. What do you guys use in your boxes & are you concerned about the tool box holding up. I'm using a Triton2 & icharger 208B for chrarging my batteries. Really need your advice guys.
_____________________________
Greg
May You Be In Heaaven A Half Hour Before The Devil Know You''''re Dead...
Hide Signatures
(in reply to waross)
       Post #: 576
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 9/18/2010 6:01 PM
Mastertech
Score: 108
Last Login: 5/20/2013
Status: offline
First Electric flight box. Changes as needed.
Be a kid forever, fly models.
Hide Signatures
(in reply to TigerI)
       Post #: 577
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 9/22/2010 1:09 PM
TigerI
Score: 100
Status: offline
Picked up a deep cycle marine battery 115Ahr to recharge my batteries at the field. Figure its big enough for some 3S & 5S batteries. Got a Battery Tender also to keep it fully charged & in tip top shape.
Greg
Hide Signatures
(in reply to Mastertech)
       Post #: 578
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 11/29/2010 12:33 AM
rambler53
Score: 122
Last Login: 5/23/2011
Status: offline
I used to buy bigger and bigger flight boxes as time passed on, being prepared for anything. There were draw backs, like somehow everyone got used to "borrowing" my glow plugs, props, screws, wing bolts, clevis's, etc. just about every weekend. Is that borrow? If I have to hit the brakes harder in transit, I feared the box would slide into a plane, again.
In spite of carrying so much with me, somehow some little thing would eventually keep me from flying anyway.
The same box grew so much, it substituted for a tool box on my building bench.
One day I hurt my back, didn't want to lift 40 lbs anymore to go fly. I got a nicad glow igniter, manual fuel pump hanging by the fuel line off my fuel cap, and an electric starter with build in 12v battery if my stick didn't get it in 4 or 5 flips. It all lays nicely on the passenger floor behind my drivers seat, and I never went back to the big box theory.
If I have a problem I need a tool for, I just go home and fix it for the next day out, and just make sure I brought a back up plane.
I don't have a field box for electric stuff either, I use the whole dining room table for a charging station with iron skillet to hold my charge bag, and just carry out what I need. I keep my radio in an aluminum case. I don't even have a screwdriver, my wings are attached already and stored that way, and they're carried in a 8' truck bed. I usually can bring 2 or 3 planes, strapped down.
If I get into a pinch, get forgetful with any necessities to get airborne, I finally get to borrow back my own stuff.
Hide Signatures
       Post #: 579
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 2/10/2011 2:23 PM
ita47
Score: 100
Last Login: 2/13/2013
Status: offline
What a cool thread from 2002! I want to thank Billy Hell for the idea and all the others who have contributed to this thread. I am new to the sport and I finally finished my ultimate field box. I bought the box last summer at Home Depot for $30 you can see pictures of the box when I bought it in my previous thread back on page 22 or 23. I wanted my power panel in the upper box so it would be easier to reach, but I wanted my battery in the lower section to keep the weight down low so the box wouldn't want to tip so easy. My solution was to use the banana plugs and some test leads from Radio Shack to connect the power from the bottom section to the top box on the left side. I also installed a power switch so I could kill the power when I wasn't using the panel or when I needed to separate the two boxes. I also added a set of banana plugs on the front. This allows me to charge the battery directly from these plugs without having to run through the panel. I can also connect my starter to these plugs and have a direct connection to the battery with heavier wire than the panel had. Next I wanted my fuel pump on the front because I don't like the idea of having it inside with the fuel but I wanted to be able to control the pump from the panel. So I used another set of banana plugs on the right side and then soldered the wire to the back of the power panel so I didn't have to plug directly into the front of the panel to use my pump. I originally wanted to use the fuel jug that the fuel comes in but it was too tall so I used my Dave Brown fuel can which is shorter and already had the ports for the fuel line built in. I had enough room to leave my Dave Brown six shooter manual pump attached to the can so if my electric pump quits then I still have my manual pump with me. This was a fun project and I am really pleased with the results. I think this will serve me well for some time.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ita47 -- 2/10/2011 4:01 PM >
Hide Signatures
(in reply to rambler53)
       Post #: 580
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 5/12/2012 3:14 AM
ckreef
Score: 105
Last Login: 5/17/2013
Status: offline
Lets go ahead and revive this old thread because it's a good one.
Read through this and it gave me some good ideas. I measured my car and measured some boxes. The good one I wanted wouldn't fit on the floor board behind the passenger seat. The ones that would were just not right. I won a $50 Home Depot gift card as a door prize so I decided to go there and make something work. This is what I came up with.
It has my 12v battery, power panel, 1 gal fuel jug with electric pump, squirt bottle of cleaner, tools, some containers for small parts etc.......  This allows me to just grab the field box, Tx and planes and I'm good to go without having to inventory everything to make sure I didn't forget anything. I've taken it to the field 3 or 4 times now and couldn't be happier.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to ita47)
       Post #: 581
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 6/11/2012 3:50 AM
realbass1
Score: 100
Last Login: 6/16/2012
Status: offline
 For you folks that have the plastic Stanley tool boxes (or any plastic field box for that matter), is there a trick to cutting the plastic out of the side panel to put the power panel in? I'm just wondering how you guys are cutting the panel out. Do i just use a sharp knife?
Thanks!
Realbass1
Hide Signatures
       Post #: 582
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 6/11/2012 3:18 PM
jsevey
Score: 100
Last Login: 3/5/2013
Status: offline
I used a new blade in a utility knife. Drill holes at each corner to run the cut into. You can also use a dremel with a cut off wheel but you will get melted plastic that has to be cleaned up.
jim
Hide Signatures
(in reply to realbass1)
       Post #: 583
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 6/12/2012 2:42 AM
realbass1
Score: 100
Status: offline
quote:
ORIGINAL: jsevey
jim
Thank you Jim!
Hide Signatures
(in reply to jsevey)
       Post #: 584
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 8/24/2012 2:13 PM
l82fly
Score: 100
Last Login: 5/3/2013
Status: offline
quote:
ORIGINAL: ckreef
Ckreef, I like all the plastic boxes but also want something more compact, I like the open bag design you created....Is that just a standard 1 gallon jug or did you purchase something that has a lower profile?
Hide Signatures
(in reply to ckreef)
       Post #: 585
RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box! - 8/28/2012 1:54 PM
ckreef
Score: 105
Status: offline
quote:
ORIGINAL: l82fly
Although I have answered this in a PM I thought I would post the answer incase other people are reading this.
That is a square, 1 gallon plastic jub that originally contained a cleaning product called  "Simple Green". I have had nitro fuel in that jug for over 3 months now with no adverse problems. I also bought that at Home Depot in their cleaning products section.
Hide Signatures
(in reply to l82fly)
       Post #: 586
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.860RCU1
