Bama
Joined: 1/24/2002 From: Prattville, AL, USA Status: offline
Cornduster, The others got the elevator question for you, I didn't even have to tweek mine, but like Robert said it would be easy to do if it was needed. I thought that was a nice touch having those already drilled, I always have to tweek them to get it just right after I drill them. I didn't have any problems with the assembly. I don't think you will either if you have put one or two arfs together. This one was no different than any of the others. I didn't make any modifications or anything. I think everything in the box was pretty good. It went together pretty fast too. I installed all the servos, engine, hooked up everything,and glued the tail on in one evening. Then finished up the tail hinging, linkages, and balancing the next evening. Alan
