aeajr
NY, USA Status: offline
Smoking Joe, I wrecked my last year. This is how you come out of a wreck better than before you crashed. My first sailplane was a Great Planes Spirit Select. The plane came ready to fly with all the electronics installed and a three channel 72 MHZ radio. It has been a wonderful plane for me. I have enjoyed it very much and would recommend it to anyone who wants to learn to fly sailplanes but doesn't want to build. Also it is very cost effective if you don't already have a radio. The cost of the ARF at about $95 plus a low cost 3 channel Hitec radio with two standard servos at $60 comes out at $155. I purchased this plane from Tower Hobbies, all built, for $139. It was cheaper for me to buy it than build it and I figure I saved myself about 6-10 hours of work. That means more flying time and flying sooner. Another thing I like about this plane is that it has spoilers built into the wings. While they are not enabled when you get the plane, they are not too hard to set-up. I flew about 40 flights without the spoilers. Then I added them and have really enjoyed learning how to add them to my flying skills. They work very well. My Spirit and I have become best buddies. I have mastered hi-start launching and enjoyed 65 great flights. I felt it was time to learn the winch, so I received some instruction from the club wizards in the use of the winch. As part of the 65 launches mentioned above, about 20 of them were winch launches that were managed by someone else while I handled the controls of the plane. We knew the plane would winch launch without problems with a little pedal management. On my third attempt to winch launch on my own, I messed up and crashed the plane hard on the launch. I considered the plane a total loss and purchased a kit. This time I would build one. A new learning step. Shutterfly photo link http://www.shutterfly.com/osi.jsp?i=67b0de21b3477855454e As it turns out, the plane was not a total loss. Using the plans from the kit as a guide, I was able to repair the wings. The damage was less then I originally thought. The servos I had put in the wings to operate the spoilers survived the crash. They worked very well, so I will keep them there. Here is one way to put a motor on a Spirit without permanently mounting it so you can fly with or without a motor. MODIFYING THE PLANE FOR AN ELECTRIC REMOVABLE POWER POD My original interior layout used two CS-61 standard servos which sat under the wing, which is the standard placement. That arrangement required about 4 oz of lead in the nose weight compartment for balance. This is pretty typical for a Spirit, or so I am told. During my learning period using a winch I crashed the plane which required lots of repairs. So, I decided to make improvements in the process. The first change was to embed about 1 oz of lead in the nose block which gets it about 1" further forward than the ballast box. Then I moved the R/E servos forward, to the rear of the receiver compartment. The standard size cs-61 servos that were already in the plane just fit here and the weight forward helped further reduce balance weight. I switched to a Micro 555 receiver, instead of the original 3 channel AM receiver so I have a channel for motor control. Its small size allowed me to use reuse the standard servos in this placement. With this 3 inch shift forward of the servo weigh, a change to the Micro 555 receiver, plus a 1" shift forward of weight to the nose block, I reduced the net balance lead and end up with a plane that is 2 ozs lighter. A second change was to switch to golden 'n rod control rods for the elevator and rudder so I could run them down the sides of the plane. The standard control rods ran down the center. This opens up the space under the wing, which is right over the CG, to accommodate a 2100 mah nicad battery pack to power the Speed 600 power pod. Now I can convert from sailplane to e-glider at will. Placing the battery directly over the CG means I don't have to rebalance the plane on the change over. With these changes I have a lighter plane and gain the flexibility to add electric power at will, or have a very convenient place to add ballast weight when I am flying in heavy wind. I always found it challenging to find a well balanced place to add ballast. Now it is easy. If you like the power pod idea, that is about $32 at www.towerhobbies.com. How's that for making the best of a crash?
_____________________________
Clear Skies and Safe Flying! Ed Anderson Moderator Park Pilot Program Partner
