2 Stroke Engine Priming
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> 2 Stroke Engine Priming
Page: [1]
Login
2 Stroke Engine Priming - 4/1/2004 9:07:56 AM
Funfly123
Status: offline
Can anyone suggest the best way to prime a fully cowled engine. The engine is an ASP 91 and it is side mounted, the fuel tank is mounted within the fuselage on the same center line as the carb there is no access to place your finger over the carb and turn the prop at the same time.
Many thanks in advance
_____________________________
Gravity always wins!!!!!!!!!
       Post #: 1
RE: 2 Stroke Engine Priming - 4/1/2004 9:34:30 AM
HavinFun
Status: offline
Put your finger over the exhaust outlet & rotate prop, works the same,
(in reply to Funfly123)
       Post #: 2
RE: 2 Stroke Engine Priming - 4/1/2004 12:04:03 PM
ooooo
Status: offline
What HavinFun said......with the carb fully open. If you use an electric starter....it is said you don't have to prime the engine. The high rate of turn over by the starter sucks the fuel into the carb anyways.
Hope this helps.
(in reply to HavinFun)
       Post #: 3
RE: 2 Stroke Engine Priming - 4/1/2004 7:56:29 PM
impactiq
Status: offline
Like said before the starter will do the job. Just do it with the glow ign. off.
< Message edited by impactiq -- 4/1/2004 3:02:37 PM >
(in reply to ooooo)
       Post #: 4
RE: 2 Stroke Engine Priming - 4/1/2004 8:50:42 PM
SwampFlier-RCU
Status: offline
Ditto on the exhaust, priming it will result in less turns with the electric starter
Regards,
Patrick
(in reply to impactiq)
       Post #: 5
RE: 2 Stroke Engine Priming - 4/2/2004 7:58:55 AM
Funfly123
Status: offline
Many Thanks for the advice
Andy H
(in reply to SwampFlier-RCU)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.562RCU1
