Sirius VS Hobbico
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Sirius VS Hobbico
Page: [1] 2 3   next >   >>
Login
Sirius VS Hobbico - 4/1/2004 3:32:58 PM
WolverineRC
Status: offline
I'm looking for a new field charger, I use mostly nicads and some Nmh batteries,
the two chargers I have been looking at are
the Sirius charge pro http://www.siriuselectronics.com/pro_ser.htm
and the hobbico Quick field charger MK2 http://www.hobbico.com/chargers/hcap0290.html
Ideally I would like two outputs, compact design, simple operation, and easy on my batteries.
any experiences with these charges or other recommendations would be greatly appreciated.
Charles
       Post #: 1
RE: Sirius VS Hobbico - 4/1/2004 7:10:03 PM
SitNFly
Status: offline
I have the older Hitec CG-335 which is great for NiCds. The newer CG-340 handles, I believe, NiMH also. These are high quality chargers with excellent peak detection.
Rein
(in reply to WolverineRC)
       Post #: 2
RE: Sirius VS Hobbico - 4/1/2004 7:39:09 PM
felker14
Status: offline
Sirius is the way to go. It is goof proof. I have the pro series with update (just done less then month ago) i have never had problem with it. Another plus to the Sirius is the warranty and the customer service they provide. Call the and ask the question you posted.
(in reply to SitNFly)
       Post #: 3
RE: Sirius VS Hobbico - 4/1/2004 8:18:44 PM
tommy s
Status: offline
I agree , Sirius is the best. Used one for years and no problems.
tommy s
(in reply to felker14)
       Post #: 4
RE: Sirius VS Hobbico - 4/1/2004 8:46:58 PM
JNorton
Status: offline
I have the Hobbico MKII. It's much more flexible than the Sirus charger. It beeps alerting you when the charge is done. It charges 4.8 or 6 volt receiver packs. Actually it charges 1 to 8 cells NiCad or NiMh or 1 to 3 cells Lithium.
I really like mine.
John
(in reply to tommy s)
       Post #: 5
RE: Sirius VS Hobbico - 5/13/2004 7:38:53 PM
beavertail
Status: offline
I dont think you can go wrong with either, The Sirius is goof proof and reliable, ie. plug and play. The Mk II is more versatile but requires more input from user.
_____________________________
Hows my flying???
Call 1-800-EAT-(Censored by Moderator)
(in reply to JNorton)
       Post #: 6
RE: Sirius VS Hobbico - 5/13/2004 10:00:27 PM
FlyNBHappy
Status: offline
Simple choice.... Sirius. No buttons to push. Just plug and charge. Flawless design.
       Post #: 7
RE: Sirius VS Hobbico - 5/14/2004 12:06:41 AM
spokman
Status: offline
Hmm, lets see.. $120 or $50? For about the same thing.
(in reply to FlyNBHappy)
       Post #: 8
RE: Sirius VS Hobbico - 5/14/2004 1:22:13 AM
RPM
Status: offline
WolverineRC -
IMHO, this is like comparing a Chevy/Ford to a Cadillac/Lincoln. Go with the Sirius and you won't regret it.
       Post #: 9
RE: Sirius VS Hobbico - 5/14/2004 2:32:13 AM
JNorton
Status: offline
Unless you've only got the money for the Chevy. They will both get you where you are going. I've had zero problems with the Hobbico MKII.
John
(in reply to RPM)
       Post #: 10
RE: Sirius VS Hobbico - 5/14/2004 4:19:34 AM
starzak
Status: offline
Sirius .... For superior technology, quality, and performance.
Batteries ain't no place to skimp !
> Jim
       Post #: 11
RE: Sirius VS Hobbico - 5/14/2004 10:39:44 PM
laryboy
Status: offline
i have heard that sirus will not work on futaba xmitters because of the famous diode in the transmitter
(in reply to starzak)
       Post #: 12
RE: Sirius VS Hobbico - 5/14/2004 11:02:07 PM
RPM
Status: offline
laryboy -
Just go to the Sirius website and they have pix with instructions on how to elimenate the Diode. It's very easily done.
(in reply to laryboy)
       Post #: 13
RE: Sirius VS Hobbico - 5/15/2004 2:47:49 AM
laryboy
Status: offline
150.00 and you have to modify your radio. no thanks
(in reply to RPM)
       Post #: 14
RE: Sirius VS Hobbico - 5/15/2004 3:46:08 AM
LMProd
Status: offline
The Hobbico or Sirius will not discharge any radio with the diode in place.
I have the Hobbico, modified my radios for discharging. I recently have switched to the Sirirus. The Hobbico started giving false readings while recycling.
       Post #: 15
RE: Sirius VS Hobbico - 5/15/2004 4:54:19 AM
