RE: Lou Andrews aeromaster bipe ..Any info ??    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: Lou Andrews aeromaster bipe ..Any info ??
Page: <<   < prev  16 17 [18] 19 20 21 22 23 24 25   next >   >>
Login
RE: Lou Andrews aeromaster bipe ..Any info ?? - 10/3/2009 3:46 PM
pd1
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: HighPlains
How old was the Aeromaster in the photo? I agree that it was silk and some form of paint, but strangely enough, Super Monokote was introduced in March 1968.
The photo looks better on my computer than the actual magazine cover does in my hands. Blown up, you can really examine the craftmanship of the structure and the finish.
The Aeromaster was started in late 1964 or early 1965.
Not only is that dope, it was brushed on. No spray gun.
The clear dope was from Waterlac, another company intown .
The color was Aero Gloss.
The real remarkable thing was the doped finish on Lou's plane was light. Probably lighter than Super Monocoat.
The method he showed me was to clear the woodwork and sand many times untill the grain was filled and the dope was shiny.
He didn't use sanding sealer or talc.
Only use thinned dope, never thick unthinned dope.
Cover with silk and again thinned dope until the weave was filled. Wet sand and a couple more coats of clear with sanding in between coats.
Add colors and a couple coats of clear and wet sand again, Rub with mild rubbing compound and wax.
Paul
Hide Signatures
(in reply to HighPlains)
       Post #: 426
RE: Lou Andrews aeromaster bipe ..Any info ?? - 10/3/2009 5:54 PM
w8ye
Status: offline
I remember doing models that way.
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to pd1)
       Post #: 427
RE: Lou Andrews aeromaster bipe ..Any info ?? - 10/20/2009 3:02 AM
aeromaster_bipe
Last Login: 3/30/2010
Status: offline
Are you still looking for the plans for the Great Planes Aeromaster Biplane? If so let me know.
Chris
Hide Signatures
(in reply to thermal)
       Post #: 428
RE: Lou Andrews aeromaster bipe ..Any info ?? - 10/22/2009 4:41 AM
proptop
Last Login: 5/9/2013
Status: offline
A friend of mine is looking for an Aeromaster kit...is there a newer issue kit available?
Seems to me that I recall reading somewhere that someone was making a new kit of the Aeromaster? (or am I imagining things? )
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
(in reply to aeromaster_bipe)
       Post #: 429
RE: Lou Andrews aeromaster bipe ..Any info ?? - 10/22/2009 4:50 AM
aeromaster_bipe
Status: offline
No new kit that  I know of yet, we just finished up mine yesterday, went out to the field to maiden it and something went bad wrong as it smashed into the pit area fence and ripped part of the lower wing off! looks like we will be able to repair it but still sux! Nice plane though!
Chris
Hide Signatures
(in reply to proptop)
       Post #: 430
RE: Lou Andrews aeromaster bipe ..Any info ?? - 10/22/2009 5:13 AM
proptop
Status: offline
quote:
ORIGINAL: aeromaster_bipe
Chris
Sorry to hear about that! Hope you can fix 'er up ok...
Welcome to RCU
Hide Signatures
       Post #: 431
RE: Lou Andrews aeromaster bipe ..Any info ?? - 10/22/2009 4:09 PM
pd1
Status: offline
The Aeromaster comes up on the Auction site quite frequently.
Kit variations.
Original Aeromaster... 48 inch wings, ailerons bottom wing only.
Aeromaster Too .........same as above with the addition of a second wing plan to allow for longer wings 52 inches.
And / or to sweep the lower wing back if desired.
Super Aeromaster By Great Planes.... Wing attachment changed to bolts. Cabane struts changed.
Nose shortened to allow for larger motor and plastic or metal motor mounts to be firewall mounted.
Wing structure changed for bolt mounts. Plastic cowl and wheel pants included with kit.
Here is a lazer cutter that advertises the "parts" to help you make one from your own plans.
I think this is a short kit only. I don't know anyone that has built this one.
http://lazer-works.com/misc.html
Paul
Hide Signatures
       Post #: 432
RE: Lou Andrews aeromaster bipe ..Any info ?? - 11/10/2009 3:29 AM
wokkabeee
Last Login: 3/22/2011
Status: offline
I just purchased an Aeromaster kit here on the marketplace for $150.00 and plan on building it over the next couple of months.  I have built two of these previously, however that was twenty years ago or more.  I'm glad to find that there are so many fans of Andrews model kits.  I learned to fly on I think it was an x-ray,  then went on to a Sportmaster which I flatspinned into a lake after putting floats on it.  Hopefully I will post some photos when I finish with the Aeromaster.  Later guys.
Hide Signatures
(in reply to pd1)
       Post #: 433
RE: Lou Andrews aeromaster bipe ..Any info ?? - 11/13/2009 6:33 AM
d boothe
Last Login: 5/10/2013
Status: offline
I just purchased two super aeromaster by greatplanes kits off ebay and another site. Will be building one very soon! Thanks for all the history and tips i cant wait to get started!
Hide Signatures
(in reply to wokkabeee)
       Post #: 434
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/2/2009 3:35 AM
d boothe
Status: offline
I Got the fuse framed and trying to decide which wing cinfiguration to build. This is the super aeromaster version from great planes. Im leaning toward the swept upper and lower which is also the larger wingspan for both wings. I plan on using a 100 saito. ive never owned one or flown one so if any of you veteran aeromaster guys are still on the up and up please give me some input. This has been a textbook build so far, hate to make a mistake. Thanks
Hide Signatures
(in reply to kpmacaz)
       Post #: 435
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/2/2009 5:06 AM
Free Bird
Status: offline
pd1,
In your opinion, which wing configuration flies the best? Besides the Aeromaster I'm refurbing, I just got a NIB kit. So I'm curious what you think.
FB
Hide Signatures
(in reply to d boothe)
       Post #: 436
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/2/2009 6:55 AM
aeomaster32
Last Login: 3/26/2013
Status: offline
The engine and wing questions have been addressed earlier. I suggest you read previous posts in order to get a broad perspective of opinion.
It's better to break ground and head into the wind than to break wind and head into the ground.
Hide Signatures
       Post #: 437
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/9/2009 3:44 AM
pd1
Status: offline
Hi fb,
I still think it's just personal preference. My next one will be with both wings swept back and 52 inch span.
The one I'm flying now is swept top and straight bottom.
Paul
Hide Signatures
(in reply to Free Bird)
       Post #: 438
RE: Lou Andrews aeromaster bipe ..Any info ?? - 1/31/2010 4:52 AM
jimbos
Last Login: 6/10/2010
Status: offline
The print sure helps me with mine, thanks!!
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to pd1)
       Post #: 439
RE: Lou Andrews aeromaster bipe ..Any info ?? - 1/31/2010 11:41 PM
buzzard bait
Last Login: 5/16/2013
Status: offline
I think it's especially pretty with the two long wings swept back. That's how I'll build mine. Nice pic!
Jim
Hide Signatures
(in reply to jimbos)
       Post #: 440
RE: Lou Andrews aeromaster bipe ..Any info ?? - 3/29/2010 2:29 AM
fishinchickens
Last Login: 7/12/2011
Status: offline
This is my .60 size aeromaster bipe. I have a .91 os fs in it. (yes i know thats alot). I finnished it when I was 14 years old. Now I am 16
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Crashing: Natures way of telling you to start building again.
WACO Brother #161
Hide Signatures
(in reply to buzzard bait)
       Post #: 441
RE: Lou Andrews aeromaster bipe ..Any info ?? - 3/29/2010 9:35 AM
aeomaster32
Status: offline
Have you flown it yet? It should fly inverted with just a touch of down trim.
Hide Signatures
(in reply to fishinchickens)
       Post #: 442
RE: Lou Andrews aeromaster bipe ..Any info ?? - 3/29/2010 2:02 PM
gene6029
Status: offline
Nice job on the build!(s) I noticed your glider isnt lacking for power either. ...Gene
Hide Signatures
(in reply to aeomaster32)
       Post #: 443
RE: Lou Andrews aeromaster bipe ..Any info ?? - 3/30/2010 1:32 AM
fishinchickens
Status: offline
It flies wonderful. I ended up moving the bottom wing up a 1/4 of an inch and setting it to 0 degrees incidence. It has much better stall chacteristics and snaps better now. When I recived it it had been through a mid-air and was going to the trash.
WACO Brother #161
Hide Signatures
       Post #: 444
RE: Lou Andrews aeromaster bipe ..Any info ?? - 3/30/2010 1:34 AM
fishinchickens
Status: offline
The glider is a gentel lady that I set up as a pun to the eletric flyers and has ended being extremely nice. The moter is .25 os max.
WACO Brother #161
Hide Signatures
(in reply to gene6029)
       Post #: 445
RE: Lou Andrews aeromaster bipe ..Any info ?? - 3/31/2010 8:21 PM
fishinchickens
Status: offline
Would any one happen to have a set of plans that are on CAD or adobie that they would be willking to share? Im thinking about building another that would be much lighter than my repair job that I did. The one I currently have is at 9.75 pounds. Its not a floater at all but still flyes good.
WACO Brother #161
Hide Signatures
       Post #: 446
RE: Lou Andrews aeromaster bipe ..Any info ?? - 6/15/2010 6:27 AM
AllThumbs
Last Login: 8/14/2012
Status: offline
If you are looking for one:
http://cgi.ebay.com/AAMCO-Aeromaster-Biplane-RC-Model-Airplane-Kit-Andrews-/220618851680?cmd=ViewItem&pt=Radio_Control_Vehicles&hash=item335de88560
Hide Signatures
       Post #: 447
RE: Lou Andrews aeromaster bipe ..Any info ?? - 6/15/2010 7:28 AM
w8ye
Status: offline
I can think of many cheaper ways to have one than to pay $325 skins for an old kit with brown plans
Original AMA #31261
Hide Signatures
(in reply to AllThumbs)
       Post #: 448
RE: Lou Andrews aeromaster bipe ..Any info ?? - 6/15/2010 7:49 AM
AllThumbs
Status: offline
Sure you can...............and watch as people crawl all over themselves to buy this..someone will buy it eventually..brown paper, silverfish and all.
Having money doesn't necessarily mean having sense either.
Hide Signatures
(in reply to w8ye)
       Post #: 449
RE: Lou Andrews aeromaster bipe ..Any info ?? - 6/15/2010 8:41 AM
w8ye
Status: offline
It's been 40 yrs since I've seen a silver fish. That would be a good way to get a colony started in your home?
Original AMA #31261
Hide Signatures
       Post #: 450
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
