F106A
NJ, USA Status: offline
Hi, For the record, IMO, the Great planes Aeromaster is a completely different animal. The Andrews kit, which I built 3, with the two wings swept, was the BEST bipe ever kitted. The wings required some care in building, but in those days you had to build your model, no ARF's. The front of the fuse was 1/2 balsa the was routed out to accept the firewall and the cabane sets, it was called Lock Box Construction, made the setting of the top wing incidence a non issue, you couldn't do it wrong! Glued to that was full length 1/8 balsa sides. Start with the recommended c/g, then keep moving it back until it snaps at the top of a loop with no input from you, then move it forward a bit. Also, make sure the aileron gaps are sealed, it makes a BIG difference in the roll rate. The original used rubberbands for both wings and the l/g, Great Planes used nylon bolts I saw the Great Plane version fly and it just didn't seem to fly like the original. I had an Enya 60 III and a Webra 61 blackhead in mine in the days before mufflers! BRG, Jon
