aeomaster32 -> RE: Lou Andrews aeromaster bipe ..Any info ?? (8/21/2008 6:59:32 AM)
quote:
ORIGINAL: aeomaster32 She looks pretty enough. Detail can add weight. Don't bolt on the wings unless you don't mind extra damage if you have a bad landing. Do solder on cross brace wire on the cabane - I can see them take on the strain when I move the top wing. Standard control surfaces give rapid enough response I have found. The original design is not something easily improved on, witness the GP later version. I might add, that I think the original landing gear design is so good, that I convert my other aircraft to that system. That gear has saved my aircraft when it contacted the ground from a too low loop. The gear rotated then sprang back, launching the plane back into the air. One chap who bolted his gear on, came up to me and said, "See, I told you it wouldn't come off the bottom". It sure didn't - it ripped out the whole bottom of the machine.
