RE: Lou Andrews aeromaster bipe ..Any info ??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Vintage & Antique RC >> RE: Lou Andrews aeromaster bipe ..Any info ?? Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/5/2006 11:12:50 PM
APIA
Status: offline
Nice airplanes pd1, after seeing these I want to get my restoration in progress. Patience Patience Patience... The red and white Aeromaster paint scheme is what I have planned, with black and yellow respectively. I have the layout with starburst on the vert fin as well in lieu of the checkerboard.
-Tom
(in reply to mcmike)
       Post #: 76
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/5/2006 11:17:25 PM
pd1
Status: offline
APIA, The yellow and black should look real nice. The checkers on mine were cut monocote, one piece at a time. I would recomend anything else.
(in reply to APIA)
       Post #: 77
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/5/2006 11:32:45 PM
APIA
Status: offline
I thought about checkerboard on the bottom of the lower wing and then I thought again about the masking and paint bleed thru. I think that I have a real challenge getting the starburst tape lines perfect. I have been researching how to get perfect tape lines and I have a few test pieces that I have experimented with and have had good results. I initially thought of recovering with plastic film, then I realized that a classic as such should be covered with good ole dope and rag... Trying to keep this airplane as nostalgic as possible.
-Tom
(in reply to pd1)
       Post #: 78
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/5/2006 11:51:37 PM
DHG
Status: offline
quote:
ORIGINAL: pd1
Your plane looks great.
If you raise the sides of the cockpit and install a round cowl, you've duplicated my Bucker.
pd1,
Is yours a scale Bucker, or a modified Aeromaster? It's gorgeous!!!
sigk,
I can tell that's an Aeromaster, but it's also very cool. What diameter is the cowl? As luck would have it, I donated a bunch of Tupperware last weekend but saved out a couple of bowls that looked like they'd hide a Supertigre S.75. Heh, heh.
HighPlains,
OK, you talked me into it, 48" span and both swept. This will teach you to drink beer at my house when you have Aeromaster plans in your possession!!!
(in reply to pd1)
       Post #: 79
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/6/2006 12:08:13 AM
mcmike
Status: offline
quote:
ORIGINAL: APIA
-Tom
Tom,
Once you get the base coat painted, mask off your trim. Then, spray the area you are going to trim in the same color as the base. One coat is usually enough, then follow that up with your trim color. Perfect lines every time. Be sure and get some good masking tape, not the manilla colored stuff, get the blue or green 'low tack' tape. It won't pull the base coat off, and won't leave any residue behind. Once you get all your trim painted, spray a couple of coats of well thinned clear over everything.. works great!
_____________________________
Real airplanes have 2 wings and round engines!
(in reply to APIA)
       Post #: 80
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/6/2006 1:05:22 AM
pd1
Status: offline
APIA,
I used to brush a coat of clear dope over the tape edge so the clear would bleed, not the new color.
Now I use green fineline tape, it makes perfect edges.
Check your local area for an automotive paint supply house.
If you can't get it locally send me a note I'll get you some.
Paul
(in reply to APIA)
       Post #: 81
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/6/2006 1:07:06 AM
pd1
Status: offline
DHG,
That's a modified Aeromaster, I posted some info on it a couple of pages back. Post # 39
< Message edited by pd1 -- 12/6/2006 1:08:35 AM >
(in reply to DHG)
       Post #: 82
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/6/2006 1:42:02 AM
Michaelj2k
Status: offline
Here's Aeromaster #1.
Click to see fullsize image.
Click for fullsize
He's crazy Lew, he,...he builds toy airplanes!
Waco Brotherhood #6
(in reply to pd1)
       Post #: 83
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/6/2006 2:25:00 AM
mradcliff
Status: offline
That's the Aeromaster I remember as an 11 year old boy at the NATS in 1965. I remember it so well, watching Ernie fly it inverted. He put on quite a show for the day considering the equipment quality of the day. My dad an I were in awe! We later built and flew one for many years. Thanks for sharing the magazine photo.
Mark
(in reply to Michaelj2k)
       Post #: 84
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/6/2006 4:57:56 AM
Michaelj2k
Status: offline
quote:
ORIGINAL: mradcliff
Mark
I also saw Ernie fly it at Willow Grove. My dad and I spent every day up there and I still recall every moment. We spent time at the ukie circles watching stunt, combat and speed, F/F scale and power and the RC events. I didn't want to see it end. Remember the closing airshow with Dick Schram "The Flying Professor", Bill Fornof flying his Bearcat and the Blues flying the Grumman F-11F? Those were real jets.
http://www.blueangels.org/History/NANews/PPPMAST/Aug69/Aug69.htm
http://www.blueangels.org/History/Rasmussen/Rasmu.htm
http://www.alexisparkinn.com/Photogallery2/DudleyHenriquesIFPF/2.jpg
Waco Brotherhood #6
(in reply to mradcliff)
       Post #: 85
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/6/2006 10:32:18 AM
APIA
Status: offline
quote:
ORIGINAL: mcmike
Tom,
That is the procedure that I used and it works great, I found the info here on RCU somewhere.
< Message edited by APIA -- 12/6/2006 10:34:22 AM >
       Post #: 86
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/6/2006 10:36:36 AM
APIA
Status: offline
quote:
ORIGINAL: pd1
APIA,
Paul
I have both, I usually have some around here at the shop and would not use anything else, Thanks for the offer...
(in reply to pd1)
       Post #: 87
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/6/2006 10:58:34 AM
APIA
Status: offline
My Aeromaster in the "bones", second pic is the mod to ailerons for the top wing.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by APIA -- 12/6/2006 11:11:38 AM >
(in reply to APIA)
       Post #: 88
RE: Lou Andrews aeromaster bipe ..Any info ?? - 12/6/2006 2:57:55 PM
pd1
Status: offline
Michaelj2k, Thanks for sharing that picture.
It reminds me that Ernie's plane was flawless, just like his flying.
