RE: Funtana 90!
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
FUNTANAS 3D .60-.90 ARF
  • 9 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: Funtana 90!
    Page: <<   < prev  169 170 171 172 173 174 175 176 [177] 178   next >   >>
    Login
    RE: Funtana 90! - 1/14/2007 6:55:33 PM
    mikey england
    Status: offline
    that should of been pulled out ok mmm not buld out ok
    (in reply to mikey england)
           Post #: 4401
    RE: Funtana 90! - 2/7/2007 8:04:58 AM
    Dirtnapper
    Status: offline
    Putting the final touchs on my Funtana. Mine is powered by an MVVS 26 gasser with the MVVS in cowl muffler. This motor was in a Goldberg Sukhoi with tuned pipe. It performed better than scale but came out at 14.5#. I'm hoping the Funtana is around 11#. I've seen so many fly at my field that I had to get one.
    I hope to maiden it in two days. Tomorrow I'll start it and make sure the fuel system and the radios work.
    I'll try to post a couple pics tomorrow.
    Dirtnapper
    (in reply to rc-sport)
           Post #: 4402
    RE: Funtana 90! - 3/31/2007 1:47:37 PM
    eigood
    Status: offline
    hi Everyone,
    I have a f90 with 'INVERTED" YS 140 Fz almost completed.
    Has anyone used the NMP Muffer set up in the F90 with this configuration ...if so did you use the inline type or sports type NMP muffler and what exhaust adapter was used?
    or could you could direct me to a post or pic showing the configuration
    Are the nmp mufflers ok?
    Thanks for any help.
    Regards
    Hanns
           Post #: 4403
    RE: Funtana 90! - 3/31/2007 2:35:37 PM
    maxun
    Status: offline
    In the forum as far I remember no one use a 140YS is too much engine for the funtana 90. May be I am wrong but I don't remember see it.
    (in reply to eigood)
           Post #: 4404
    RE: Funtana 90! - 3/31/2007 5:21:29 PM
    davebart
    Status: offline
    Has anyone put a Zanoah 20 in one?? I have a slow connection and there are 177 posts here. If you did, can you help with the standoffs needed, etc. Thanx, Dave
    _____________________________
    If you are not having fun ... you are not doing it right.
    (in reply to Zeeb)
           Post #: 4405
    RE: Funtana 90! - 3/31/2007 6:54:46 PM
    rcdivot
    Status: offline
    Read faster.....
    (in reply to davebart)
           Post #: 4406
    RE: Funtana 90! - 4/1/2007 5:58:56 AM
    Scooterpilot
    Status: offline
    Davebart,
    I know if you look in the Funtana 100X thread you'll find that someone installed a Zanoah 20 in it.
    Regards
    Scooterpilot
    Magnum Fuel
    (in reply to rcdivot)
           Post #: 4407
    RE: Funtana 90! - 4/1/2007 12:52:25 PM
    eigood
    Status: offline
    hi,
    Quite a few used Ys140 with 18x6 wide APC prop....need to use throttle management though. need longer main gear...i am using the old Bolly CF Extra main gear....fit perfectly and less that 1/2 the weigh of the gear supplied.
    Any one use the NMP mufflers before?
    Regards
    Hanns
    (in reply to maxun)
           Post #: 4408
    RE: Funtana 90! - 4/1/2007 4:04:03 PM
    davebart
    Status: offline
    Thanks Scooterpilot. That was one of the next places to go since the Z 20 is so new. I have a 1.50 Saito in it now and wanted to try gas. this will be my first gas plane.
    Dave
           Post #: 4409
    RE: Funtana 90! - 4/8/2007 10:35:48 PM
    ^Horatio>
    Status: offline
    I flew my F90 for the first time yesterday. I'm using a Moki 1.35 on 5% nitro (Model Technics 'Formula Irvine') and a 17x6 prop. The engine was recommended by the chap from Just engines who sadly passed away last year.
    All I can say is 'wow'. This is my first real experience with a 3D aircraft and I have to say that the threads here on RCU have been a god-send.
    Just as TManiaci recommended, I used around 50% rates and 30% expo, and 70% expo for the 3D settings. I programmed the aileron differential as per the manual and also set up some flaps for the landings.
    The take off was text book perfect, the plane was perfect and required ZERO trimming whatsoever. You know that anxious feeling you get when you first put a new plane in the air? Multiply that by a factor of 10 and that's pretty much how I felt, because it's been at least 3 years since I've flown anything fixed wing and people kept telling me - 'oh, you got to be careful with that F90, tricky plane to land, drops a wing etc blah etc....'
    Well I'm happy to report the plane was awesome. I'm no 3D pilot, but I've got a good feeling that I'll be a much better flyer come the end of the summer. I put the CG at just a shade in front of 7" and it flies lovely like that. Crisp, smooth and responsive but without being twitchy. The engine could pull vertical at 1/2 throttle no probs and lasted a good 20 minutes on the tank, at which point I decided to bring it in.
    A slight drama unfolded as we realised the main landing gear had lost a bolt and skewed around by 90 degrees - as in TOTALLY perpendicular to the direction of motion. So I had to make this a good landing first time. After thanking the supportive folk who gathered to watch me destroy my F90, I switched on the flaps and cursed quietly to myself. I flew as slow as I dared, brought it in nice and flat and made sure that I cut the throttle as soon as the first wheel pant touched down. The Funtana came to a pretty smooth stop considering, and other than a slightly bent aluminium landing gear, nothing was broken either - not even the wheel pants. Incredible. The entertainment was much appreciated by the other club members who gave me a small cheer.
    Performance-wise, I really cannot fault this aircraft's maiden flight. It's one of the easiest planes I've ever flown. I can't wait to fly it properly.
    Want free stuff? Visit this link, sign up and tell your friends!
    http://ipods.freepay.com/?r=42763668
    (in reply to skyriter)
        &top=500 title="Search users posts" target=_blank>   Post #: 4410
    RE: Funtana 90! - 4/9/2007 7:26:21 AM
    davebart
    Status: offline
    Jolly good report there Horatio. Happy that you landed it safely. Have fun....
    (in reply to ^Horatio>)
           Post #: 4411
    RE: Funtana 90! - 4/9/2007 3:20:22 PM
    visioneer_one
    Status: offline
    quote:
    ORIGINAL: ^Horatio>
    Funny you should mention this. One of my mates has a F90 and has had the same thing happen to him.
    TWICE.
    The first time this happened we were all helping to clear a spot in the tall grass when one of the guys noticed that the gear was rotating and appeared to be unscrewing the remaining bolt! My mate then flew snaproll after snaproll, which completely unscrewed the other bolt, allowing the gear to fall free. He was then able to belly-land the Funtana on the grass. No damage besides a broken prop.
    The second time this happened he applied te same solution - multiple snaprolls till the gear fell off, then a nother smooth belly landing.
    Turns out that he used a slightly undersized bolt to replace the first one that fell out. Both were locktited in place, but were no match for the vibration of his YS 1.20.
    He has since replaced both bolts with longer ones, and has bent over the piece of each bolt that protruded above the blind nuts. They will NEVER come out again.
    BTW - a Funtana with no landing gear looks a LOT like a P-51.
    The statement below is false.
    The statement above is true.
           Post #: 4412
    RE: Funtana 90! - 4/9/2007 6:16:50 PM
    ^Horatio>
