RE: Funtana 90!
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
FUNTANAS 3D .60-.90 ARF
  • 4 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: Funtana 90!
    Page: <<   < prev  169 170 171 172 173 174 175 176 177 [178]
    Login
    RE: Funtana 90! - 8/29/2007 2:46:32 PM
    SpectrePilot
    Status: offline
    Someone is selling a NIB Funtana 90 on here for $225.00 claiming the kit is out of production. HH is out of stock. Anyone else heard it is out of production?
    (in reply to saltywheels)
           Post #: 4426
    RE: Funtana 90! - 8/29/2007 5:10:19 PM
    opjose
    Status: offline
    Yes it's long gone. Over a year or more ago.
    I purchased my Funtana 90 the month before it was announced that it would be withdrawn.
    Sigh... three planes in a row I've had this occur with...
    _____________________________
    Build em'', fly em'', crash em'' and build more.
    (in reply to SpectrePilot)
           Post #: 4427
    RE: Funtana 90! - 8/29/2007 9:14:51 PM
    saltywheels
    Status: offline
    yep its been out of productions for about a year or so, I also got mine a couple o' months before they came out with that awesome funtana 100....
           Post #: 4428
    RE: Funtana 90! - 8/30/2007 6:15:35 AM
    maxun
    Status: offline
    The new funtana is the X100, is improve and they say it's better than the S90, I don't know my S90 is super nice, I still have it in the hall of fame, but to replaced in the future will be the X100
           Post #: 4429
    RE: Funtana 90! - 9/4/2007 3:57:52 AM
    davebart
    Status: offline
    I have an engine issue I need some help resolving. I have a Funtana 90 that had a Saito 1.50 in it. I didn't like the way the cowl was cut and wanted to add a slim-line muffler but had trouble fitting it. I have a Zenoah 20 gasser in the box and thought this may be the perfect engine for the Funtana. Here is my problem. When I fit the Z20 so that the prop shaft is centered in the old cowl, the base of the engine is way over to the left side of the engine box. So much so, that if I drill the holes for the two screws on that side (left from pilots view) they would almost go into the side of the engine box. The blind nuts would almost have to be cut in half to fit. Hopefully I have explained this and I can take pictures if an expert comes forward to help. I am about ready to go back to the Saito.
    Thanks, Dave
    If you are not having fun ... you are not doing it right.
    (in reply to maxun)
           Post #: 4430
    RE: Funtana 90! - 9/4/2007 12:31:26 PM
    maxun
    Status: offline
    first, this plane is not designed for gas engine, too much vibration, second yes go back to your saito.
    (in reply to davebart)
           Post #: 4431
    RE: Funtana 90! - 9/7/2007 11:57:17 PM
    saltywheels
    Status: offline
    well I finally weighted my funtana now after about a year and a half. It came out 7.9lbs dry, with saito 100. I tryed it 5 times with the same answer. What have everyone elses planes been weighing in at, I'm just curious because mine is really light.
    (in reply to maxun)
           Post #: 4432
    RE: Funtana 90! - 9/11/2007 5:48:49 PM
    maxun
    Status: offline
    Dude, just fly the plane and make shure it will hover in haft troutle, if the plane can't mantein hover in half them change the engine to a YS and enjoy the full advantage of this model.
           Post #: 4433
    RE: Funtana 90! - 9/12/2007 10:10:15 PM
    saltywheels
    Status: offline
    It can hover very well ad here is the video of it if you don't believe me. Its pretty cool.
    http://youtube.com/watch?v=DuR7ROPAZLw
    (in reply to maxun)
           Post #: 4434
    RE: Funtana 90! - 10/14/2007 3:32:20 AM
    Leemata
    Status: offline
    Too many post to read through so Ill ask a question I'm sure has been answered already. What is the best prop to use with an O.S. .91FX on the Funtana S90? Thanks in advance.
    Terry
    (in reply to krayzc-RCU)
           Post #: 4435
    RE: Funtana 90! - 8/18/2008 10:54:04 AM
    johannmicallef
    Status: offline
    I had been using an OS 91 FX and i tried many props the best on that ii found was a 14/4 prop an 15 inche prop seemed to big for the engine but any way i have changed the engine because the os 91 fx was a bit under power it dosent even let me do a prop hang so i decided to buy one and i bought a Saito FA-125A.Here is a sample video of my Funtana S90 that my friend did for me.
    http://www.youtube.com/watch?v=6UOHAb1ocEc
    (in reply to Leemata)
           Post #: 4436
    RE: Funtana 90! - 8/19/2008 12:52:14 AM
    opjose
    Status: offline
    The Funtana - NEEDS - a BIG low pitch prop so you get a lot of thrust but do not overspeed the plane ( which is usually fatal... ).
    The OS .91 could easily handle a 16x4W. You should try one.
    I fly my Saito 1.00 FA on my Funtana s90 with a 16x4W prop and verticals are no problem what-so-ever.... my standard takeoff is straight up.
    The manual recommends this prop for very good reason.
    (in reply to johannmicallef)
           Post #: 4437
    RE: Funtana 90! - 8/19/2008 1:03:11 AM
    airraptor
    Status: offline
    OS120 AX with 17x6 or 18x6 prop no less
    to fly with saito 100 or OS 91 but be a real dog to hover. mine is 10 lbs full of fuel.
    mine turns an APC 17x6 around 9,400rpm
    (in reply to opjose)
