manion_30
GA, USA Status: offline
Hi shane, I had Larry heli setup 101 almost a full page on CCPM, pitch/throttle curves instructions engine vs pitch vs tail rotor, all of it and RCU program dumpped it. So I will do a quick version. CCPM setting: the +60s are the amount of movement in degrees that elev and ailer can move separately. the -85 is th pitch change for all three servos together this would be max pitch, the neg is another way some radios program reverse the direction of travel and still mix together. It look like you are running to much positive pitch unless you compensated with the pitch curve #5 to adjust to +12 deg or so. My venture 30 is set very close to your setting and they are not right, but the only way to adjust the -2 deg at idle. To much pitch the engine will not maintain the power at or close to full throttle or the RPM will drop creating lots of heat. I strap my heli to a table leaving enough room (1 in.) to see the response as i make adjustments, set engine speeds to max power. However, the purpose is to maintain rotor RPM for any pitch change - 0 and + Training 1600-1800 and advanced 1800-2000 RPM. If you are still training I would pick 1800, set you pitch curve for the max, min and hover (hover ether +5 or 0 deg) as per the book and try to adjust you throttle curve to that RPM. I use a tack in foam rubber in front while running and set the radio setting to maintain Rpm from just before hover adjust throttle curve #3 and keep advancing the throttle through #4 and max power #5 for the same Rpm. Then go back to the engine setting for proper max power minus 200 to 300 Rpm rotor speed for rich setting. Now, the rotor rpm is constant and engine rpm is constant the tail rotor has little choice, it remain constant except for increased pitch in the tail. you now trim out the tail rotor in normal mode and then in HH mode, now back to rotor rpm engine settings if changed. Now, the only thing effecting the tail is you telling it where to go, which, changes rotor/engine rpm, but properly trimmed the tail will be more stable, less corrections, easer for the gyro/tail servo. When you advance to flight mode 1 and 2, you will need to adjust pitch/throttle curve #1, #2, #3 for the negative pitch for the same rpm. You can now adjust you tracking easier, set trim for ail/elev, refuel and fly. you should not need any other adjustment except for final trim for hover. These are critical for proper tail control, advancing to forward fly, and the best stability overall. This is a condensed version and might be a little easer to understand the big picture (constant rotor RPM). I have a link that shows more than I can explain. http://www.moretraction.com/new_page_3.htm Larry
