Fubar-One
Joined: 3/1/2003 From: Canyon Country, CA, USA Status: offline
Copy. Add to Fav. Copy. Add to Fav. Great info, guys! quote:
ORIGINAL: mr.rc-cam quote:
Is the correct one to order $13.95? It is $15.00 from Digi-Key: http://dkc3.digikey.com/PDF/T041/0521.pdf quote:
I have a feeling I need to remove the RF module from the circuit board to see anything that looks like the links you gave me Do not do that (leave the sardine can alone). All you need is access to the Tx's antenna connection (where the coax solders to the PCB). Remove the antenna coax, and using a VERY short wire (mine was about 0.2" long), connect the BBA-519's input to it. The antenna coax will go to the BBA-519's RF output. All Linx grounds go to the Tx's RF ground, which is essentially the massive copper copper plane on the Tx's PCB. Do not skimp on the RF gnds! quote:
Is the backing circuit board needed at all, or just the TX section? I installed mine "deadbug" style, per the photo shown in the link I posted. Yb2normal did the opposite. Use whatever method is easiest for you to use. The goal is to install the RF Amp with VERY short leads. At microwave frequencies, the wires become efficient inductors and really mess things up.
_____________________________
"B Positive to ground, over..."
