12v LawnMower Battery wont charge Receiver Packs
Tower Hobbies
Logged in as Guest
  Printable Version
FISHER FUEL PRODUCTS 5 GALLON & 2.5 GAS FUELERS
Seller:  hunternfla
Details:   $220.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> 12v LawnMower Battery wont charge Receiver Packs
Page: [1]
Login
12v LawnMower Battery wont charge Receiver Packs - 4/6/2004 6:42:23 AM
UltraMan
Status: offline
I am currently using a 12v Lawn mower lead/acid battery to charge my Receiver packs. I have a Hobbico Field charger (not the MKII). With this configuration i can not fully charge my 1800 nicad or my 1650 NIMH packs. The full charge light on my charger never blinks, even after 30 mins of charging. It will fully charge my 600 mah however. The lawn mower battery is new, and fully charged. What can i do???
Thank
Chris
       Post #: 1
RE: 12v LawnMower Battery wont charge Receiver Packs - 4/6/2004 10:54:56 AM
JNorton
Status: offline
It's the charger it was not designed for large packs only up to 800 mAh.
SPECS: Min.in voltage: 11vDC
Max in voltage: 14.3vDC
Weight: 12oz
Case dimensions: 6.28"L x 3.92"H x 1.28"Depth
Fuse: 2.5A 250 Volt
Fast charge: TX-800mAh RX-800mAh
Trickle charge: TX-70mah RX-70mAh
John
(in reply to UltraMan)
       Post #: 2
RE: 12v LawnMower Battery wont charge Receiver Packs - 4/6/2004 12:00:38 PM
Geistware
Status: offline
The original hobbico charger will put out 1200maH before it goes into time out. You can charge the pack more often (after less than 1200maH has been removed) or you can charge it twice. This later is what I did with my 1800maH NiCad packs.
_____________________________
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
(in reply to JNorton)
       Post #: 3
RE: 12v LawnMower Battery wont charge Receiver Packs - 4/6/2004 2:34:26 PM
laryboy
Status: offline
there is nothing wrong with charger. if your battery was half full, it would take about 1 hour before peak detecting. if batt is empty or even a larger pack is used the inernall timer may run out and stop charging. use giestwares suggestion and just restart charger.
(in reply to Geistware)
       Post #: 4
RE: 12v LawnMower Battery wont charge Receiver Packs - 4/6/2004 4:16:31 PM
Shortman
Status: offline
I would recommened buying a new charger, the Great Planes Triton is awesome and will charge all r/c battery chemistries. It allows you to see the exact amount of Ah put in the battery and how long it took and the charge rate set by you.
Steven Carroll
AMA# 738035
(in reply to laryboy)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU4
