yukonho
Joined: 3/29/2004 From: montreal, QC, CANADA Status: offline
If you only get 2 minutes runtime, something is wrong. First of all, NiMh cells take several cycles to get up to full capacity. If they are new cells give them some time. Second, check every single place on the heli that can cause drag or friction. Gear mesh for main and tail motors is the first thing to check. Check to see everything turns VERY freely with no binding at all. Check flybar paddles for alignment. If your main or tail motor or batteries are old, they may be the problem as well. Take your time and go over everything, co
_____________________________
So, we're on our bikes and we're goin' like90 down this hill. Then this heli comes out of nowhere and gets stuck in my front
