RE: composite arf yak?
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Yak-55SP 2.6m
  • 2 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: composite arf yak?
    Page: <<   < prev  61 62 63 64 65 66 67 68 [69] 70   next >   >>
    Login
    RE: composite arf yak? - 7/7/2007 7:02:10 PM
    DesertHucker
    Status: offline
    I made sure I had about 12mm 1/2" between the headers and canisters. You could see the carbon buildup on the teflon joiner after the crash that the gap was constant.
    Going to use the KS canister mounts this time they look to be a good thing nothing should move.
    http://www.krumscheid-metallwaren.de/neu/showarticledetails.php?lang=EN&anr=501#
    _____________________________
    Lawrie Goldfields Aeromodellers
    www.gam.asn.au
    (in reply to amjflyer)
           Post #: 1701
    RE: composite arf yak? - 7/7/2007 8:41:13 PM
    Allan B
    Status: offline
    If you "connect " your engine/motor to the cannisters with an eletrical wire, then there should be no problems.
    I haven“t given that a thought on my model (Extra) -not with a 12 mm spacing anyway! - I have a few millimeters!
    But now I probably will give it a thought!
    Reg
    Allan B
    < Message edited by Allan B -- 7/7/2007 8:42:20 PM >
    (in reply to DesertHucker)
           Post #: 1702
    RE: composite arf yak? - 7/8/2007 10:57:36 AM
    Torben Parsberg
    Status: offline
    hi
    I must pay 1500 euro ,, but it super duper JOB they doo . over ther .,..,
           Post #: 1703
    RE: composite arf yak? - 7/8/2007 6:53:19 PM
    amjflyer
    Status: offline
    KS clamps are nice, better design than Greve i think. The mounts probably benefit from soft mounting, and that would probably also prevent the movement ('creep').
    "If at first you dont succeed, try and try again"
    - but resist taking up skydiving...
    (in reply to Torben Parsberg)
           Post #: 1704
    RE: composite arf yak? - 7/8/2007 7:58:44 PM
    Tired Old Man
    Status: offline
    Cut a soft spacer of the same material (but smaller diameter) the sleeves are made from to fit between the pipes. You could use an automotive heat resistant hose if that's all you could find.
    If you can''t fix it with a hammer, you have an electrical problem.
           Post #: 1705
    RE: composite arf yak? - 7/9/2007 2:30:37 AM
    wifpwcf
    Status: offline
    hi guys ..hey lozza sorry to here about ya yak mate .are you using 2.4 again ..
    her is a vid of me yak bully on the weekend.she has been resting for 4 months time to fly her again
    cheers glen
    http://www.youtube.com/watch?v=Nz4W9uDrAGo&eurl=http%3A%2F%2Fwww%2E3d%2Ddownunder%2Ecom%2Fforum%2Fviewtopic%2Ephp%3Fp%3D29826
    TEAM AUSTARS,TEAM TO MUCH FUN CLUB
    TEAM BIG COURAGE DIAMONDS
    (in reply to Tired Old Man)
           Post #: 1706
    RE: composite arf yak? - 7/28/2007 3:31:28 PM
    mrc100
    Status: offline
    I'm having trouble determining where the control horns should line up with the aileron hinge axis? This is a bit confusing because the ailerons are hinged to the top surface of the wing. So is that the axis or is it some other reference? The illustrations in the manual make it seem like there is a reference on the bottom of the wing, but on mine there is a gap between the aileron and the wing.
    Any suggestions?
    Mike
    (in reply to wifpwcf)
           Post #: 1707
    RE: composite arf yak? - 7/28/2007 5:30:51 PM
    Tired Old Man
    Status: offline
    By the time you get the slots for the aileron horns cleaned out and cut the horns to the correct length you'll be close. In any case, try to get the holes for the clevises to roughly align vertically with the hinge line on the top of the wing. If you're going to use dual aileron servos do everything you can to make sure all the horns line up at the same relative point.
    You will have to cut the horns to obtain the correct lengths and alignment. Careful here because it's quite easy to cut the wrong angle at the bottom of the horns. I found using a Dremel cut off wheel is about the best way to cut the phenolics. Pay close attention to the hole heights as noted in the instructions, remembering that the outside horns have a different apparent height that compensates for the thinner aileron section. Having them wrong in height or hinge point alignment will bugger up the aileron control set ups.
    < Message edited by Silversurfer -- 7/28/2007 10:11:15 PM >
    (in reply to mrc100)
           Post #: 1708
    RE: composite arf yak? - 7/28/2007 7:20:22 PM
    mrc100
    Status: offline
    Thanks for the help silversurfer! Have a great day.
           Post #: 1709
    RE: composite arf yak? - 8/19/2007 12:07:39 AM
    Torben Parsberg
    Status: offline
    Hi
    Now its get 1 flight and 3 other after
    YAAAR its great
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
           Post #: 1710
    RE: composite arf yak? - 8/19/2007 4:55:28 AM
    RTK
    Status: offline
    Nice baffling, do you have any directional flow on the back side of the cylinders ??
           Post #: 1711
    RE: composite arf yak? - 8/19/2007 7:02:58 AM
    wifpwcf
    Status: offline
    hi guys i just fitted a mvvs116 to my yak.was a 3w & now i thought i would try some thing diffrent.
    i had 230grams in the nose for a good c/g now i dont need the weight so im happy & more power to.
    gota love power.I will be running the 3204mvvs cans & a 30x10 prop.
    cheers glen
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    < Message edited by wifpwcf -- 8/19/2007 7:07:10 AM >
    (in reply to RTK)
           Post #: 1712
    RE: composite arf yak? - 8/19/2007 8:14:37 AM
    Torben Parsberg
    Status: offline
    hi RTK
    no . just 1,5mm balsa and 25g fiber both sides
           Post #: 1713
