RE: DD Tail Mount.
Tower Hobbies
Logged in as Guest
  Printable Version
Align T-Rex 500 - RTF
Seller:  BladeRunner2002
Details:   $849.00   |  10/4/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> RE: DD Tail Mount.
Page: <<   < prev  1 [2]
Login
RE: DD Tail Mount. - 4/16/2004 5:05:04 PM
justin_92_92
Status: online
no I fly mostley in doors......would the lightend heading hold gyro work for me at heelihobby? My problem isnt really bad now....I can get it to hover in the air but then little by little the tail creaps right....I am not good enough to correct this while it is in the air yet htough.. I tend to lose alltitude when I do or I lose controll...whichever comes first.
(in reply to RickyT63)
       Post #: 26
RE: DD Tail Mount. - 4/16/2004 5:32:02 PM
RickyT63
Status: offline
With tail facing you and it's turning to the right (head turns left) ? On my jabo with stock board & DD tail, it's the opposite!
I used to have same issue of controlling too. Either I lost altitude & crashed or lost control & crashed!
Dont give up, Justin. Keep on practicing. it will eventually get to you real soon. If you can hook up Tx to FMS, it would help getting hand-eye cordination.
Regards
(in reply to justin_92_92)
       Post #: 27
RE: DD Tail Mount. - 4/16/2004 5:37:04 PM
justin_92_92
Status: online
i have a flight sim but no cord to connect my tx to pc. I am excpecting my dd to arrive today. cant wait to get the bad boy in the air again. I have stopped braking landing gear every time I fly now though. Now its every 3 times I fly I break them lol. I am alot better then my buddy is whith his aerohawk though. He put the duct fan on and it wont leave the ground now dues to unballanced and when he ballences it he has to add weight to it and its too heavy lol. he is going to a plain dd style like mine soon though.l
       Post #: 28
RE: DD Tail Mount. - 4/16/2004 9:01:59 PM
BENZITO
Status: offline
Ricktran which one did you buy from aeromicro? There are so many choices ??
       Post #: 29
RE: DD Tail Mount. - 4/17/2004 1:00:44 AM
BENZITO
Status: offline
Thanks for the info Antrock I got the motor and the props coming to do a reverse cooling system that you have. What is it that you used to hold the motor in place? Thanks
(in reply to BENZITO)
       Post #: 30
RE: DD Tail Mount. - 4/17/2004 2:25:30 AM
mdttb
Status: offline
check out this thread
       Post #: 31
RE: DD Tail Mount. - 4/17/2004 3:05:18 AM
BENZITO
Status: offline
LOl i didnt realize it was you making them I need 2 as you can see in my post,Thanks
(in reply to mdttb)
       Post #: 32
RE: DD Tail Mount. - 4/17/2004 7:09:43 AM
RickyT63
Status: offline
Benzito,
Are you asking about HH gyro? If so, I havent bought it yet. Just gather all info and save up $$$.
BTW, I'm gunning for Futaba GY240 or CSM G200.
< Message edited by RickTran -- 4/17/2004 2:10:09 AM >
       Post #: 33
RE: DD Tail Mount. - 4/17/2004 12:56:03 PM
BENZITO
Status: offline
No but thanks I was inquiring about the dd setup . You have all been very helpful
       Post #: 34
RE: DD Tail Mount. - 4/17/2004 3:13:21 PM
RickyT63
Status: offline
Benzito,
Oh,ok.
You can buy DD tail motor/blades from most shops for ~$11.00. Part# GWS EDP 50XC.
For DD tail mount you can get from Mdttb's link above. (I really like his design).
       Post #: 35
RE: DD Tail Mount. - 4/19/2004 5:49:34 PM
antrock
Status: offline
Benzito,
go to this link and towards the bottom you will se a post with the part # and drill bit sizes http://www.runryder.com/helicopter/t82139p1/?highlight=mcmaster.
i also drilled small holes on each side and used set screws instead of CA. and a hole all the way through so i can place a graphite rod so the tail blades do not hit the ground on a rough landing. also be careful not to use too much ca on the blade or it will creap into the motor and i am sure you know what happens from there.
good luck.
       Post #: 36
Jump to:
Google
