RickyT63
Joined: 12/22/2003 From: San Jose, CA, USA Status: offline
Zeeshan, For DD tail motor (EDP-50xc) you can switch wires & blades to make it spin the other way. With helis tail facing you, blades with be on the right side for normal mounting. With reversed wires/blade mount, it will be on the left. Just remember that you need to reverse both wires & blade for it to work. Lastly, lots of posts I've read that DD tail works fine with aerohawk. BTW, I've just switched from DD tail to dual stock tail setup. Performance wise is about the same but dont know how long they last. Regards
< Message edited by RickTran -- 4/14/2004 8:07:19 PM >
