Gravityisnotmyfriend
WI, USA Status: offline
I have two tower engines. One, that I bought new, runs like a champ - makes tons of power. After its warmed up, it will start with one or two flips of the prop. The other one, which was given to me, has never run right (that's why it was given to me). If I tune it for WOT it makes monster power, but won't idle. If I tune for idle, it dies in the mid-range. But, after reading Bax's post, I'm flabberghasted. I've been reading all I can about engine tuning. As someone else said, it does appear to be a black art. From what I understood, you always tune the low speed first, then the high speed. I thought that the low speed settiing affected the high speed, but not the other way around and that's why you adjusted the low speed first. I also thought that I was well informed that these engines leak around the front bearing. I presently have my poor running engine dismantled with the intention of replacing the front bearing. I did a search to find more info and came across this thread. I guess I'll put it back together and see what I can do. If I can get this one to run like my other one, I'll be a very happy guy.
_____________________________
The mathematician sees the glass as twice as big as it needs to be. The engineer sees it as full with a Safety Factor of 2.
