2 questions...fuel tank / engine life
Tower Hobbies
Logged in as Guest
  Printable Version
HPI SAVAGE 14MM HEX HUB WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $22.00   |  10/23/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> 2 questions...fuel tank / engine life
Page: [1]
Login
2 questions...fuel tank / engine life - 4/14/2004 5:58:23 AM
statenine
Status: offline
Fist question. Is there anywhere to buy a larger size fuel tank for the rc10gt?
2nd, On average, how long do these stock rc10gt engines last with proper care and maintenance?
       Post #: 1
RE: 2 questions...fuel tank / engine life - 4/14/2004 6:22:25 AM
rc10gt4master
Status: offline
the engine life realy depends opn what type of racer you are. if you run hard for long your engine wont last as long as your typical easy going racer, as for the latger fuel tank go to neweramodels.com and they have a 125 cc fuel tank for the gt
(in reply to statenine)
       Post #: 2
RE: 2 questions...fuel tank / engine life - 4/14/2004 7:16:22 AM
statenine
Status: offline
Thanks, I orderd that fuel tank. As for the engine....I dont race at all, just bashing maybe 3 times a week only 1-2 hours each time. I know it varies...but can it last 1 year, 2 years? On 'average' what is the life expectancy? thanks for the info
(in reply to rc10gt4master)
       Post #: 3
RE: 2 questions...fuel tank / engine life - 4/14/2004 5:44:22 PM
rc10gt4master
Status: offline
well i didnt mean race at the track but i just meant playing with your truck sorry for not verifying that, but my engines only last a few months before i rebuild because i drag race my GT's and wen i practice and just bash i bash hard. my engine hardly every see's quarter throttle its always 3/4 or full that is why i rebuild so much but in your case your engines should last 8 to 10 months if properly taken care of. use after run oil and when you store them make sure you plug the carb. have fun!!!
       Post #: 4
RE: 2 questions...fuel tank / engine life - 4/14/2004 6:41:56 PM
statenine
Status: offline
wow not a very long life expectancy huh Yea I use after run oil every time I am done bashing it...I was hoping it would last at least a year When it does come time to rebuild....what parts am I looking at replacing? Or is it cheaper to just buy a new motor? thanks for the help so far
       Post #: 5
RE: 2 questions...fuel tank / engine life - 4/14/2004 7:06:21 PM
gmac4826
Status: offline
if its an RTR engine, dont rebuild. it costs more than the whole engine. i suggest buyin an os becasue someone on ebay or something rebuilds for like 20 bucks
_____________________________
Who needs brakes?? All they do is slow you down.
       Post #: 6
RE: 2 questions...fuel tank / engine life - 4/14/2004 7:34:16 PM
statenine
Status: offline
Ahh ok thanks. Is there an os engine that will bolt straight into my existing motor mount? And what is the biggest size engine I can fit in it? Thanks!
(in reply to gmac4826)
       Post #: 7
RE: 2 questions...fuel tank / engine life - 4/14/2004 7:40:21 PM
statenine
Status: offline
Is this a good engine and will it bolt right into my rc10gt?
http://www.osengines.com/engines/osmg2051.html
       Post #: 8
RE: 2 questions...fuel tank / engine life - 4/14/2004 9:02:16 PM
rc10gt4master
Status: offline
that is a great choice but if you can get a slide carb it would be better... your engine will last amny years if you dont play wityh it all the time like i do and like you say you do but invest in an OS engine and you will recieve more power and it is only 30 to 40 bucks to rebuild them... to re byuild them just replace piston piston sleeve and connecting rod... im not sure if you have to replace the con rod but i do
       Post #: 9
RE: 2 questions...fuel tank / engine life - 4/14/2004 9:03:26 PM
rc10gt4master
Status: offline
oh yeah for the bolt on part you wll need to cut the shaft that is all...make sure you get the treaded shaft so you can cut it adn you will need to get a clutch nut for the threaded shaft...5 bucks...
       Post #: 10
RE: 2 questions...fuel tank / engine life - 4/14/2004 9:30:51 PM
statenine
Status: offline
Well on the OS website it says they have a short shaft version for my truck:
The .15 CV-R is available in these four carb/shaft configurations:
Standard Shaft with 10E Rotary Carb
Standard Shaft with 10A Slide Valve Carb
Pilot Shaft (P) with 10A Slide Valve Carb
Short Shaft (S) with 10E Rotary Carb
The last one is made to fit the rc10gt they say, but it is only available in a rotary carb. So your saying I can buy the standard shaft with a slide carb then just cut down the shaft length?
       Post #: 11
RE: 2 questions...fuel tank / engine life - 4/15/2004 1:58:07 AM
rc10gt4master
Status: offline
that is correct... you will need somthin called a cut off nut i am not sure if you have it but you put the flywheel on and then the cut off nut and it is the correct length that you nees...all you have to do is take a dremel or a hack saw and cut it flush with the nut..easy as 1 2 3...if you need any further help just ask
       Post #: 12
RE: 2 questions...fuel tank / engine life - 4/15/2004 2:23:19 AM
GT-Power
Status: offline
only thing is for racing that O.S. wont be allowed. also on break in i put a few drops of motor oil in (very light weight) and make sure i lube the engine in and between cool downs i put a good bit of after run oil in. after i did this my engine ad a tighter seal and seemed to last longer. just like our bodies: if we dont have blood we dont live! same with our engines!
       Post #: 13
RE: 2 questions...fuel tank / engine life - 4/15/2004 4:24:42 AM
statenine
Status: offline
yea good idea...thanks for the input guys
Yea I wont be racing at all, so its ok with me if its not allowed. Can one of you maybe point me in the right direction for the cheapest online price for this engine? Thanks!
(in reply to GT-Power)
       Post #: 14
RE: 2 questions...fuel tank / engine life - 4/15/2004 4:55:12 AM
statenine
Status: offline
Oh, also....is there actually a performance difference in using a slide carb vs. a rotary carb? Why do you recommend the slide carb instead? Im just curious why 1 is better than the other thanks
