GP Super Stearman
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Super Stearman
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> GP Super Stearman
    Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
    Login
    GP Super Stearman - 4/15/2004 12:07:39 AM
    ghost-RCU
    Status: offline
    They are in stock and mine is on the way. I've been flying Helicopters for the most part the last three years but this plane has me all excited about flying airplanes again. Now I need to decide on an engine. I'm thinking about an OS 1.20 pump, YS 1.40 sport, or a Enya 1.55. It will be mounted inverted. I've been leaning towards the Enya but not sure how well she idles without constant glow heat at low RPMs. I could put an onboard glow igniter on her but would rather not if I can get away with it.
           Post #: 1
    RE: GP Super Stearman - 4/15/2004 2:52:48 AM
    rc-sport
    Status: offline
    I'd go with the 120, this plane is not doing to need 3D power. The pump will help it run inverted.
    (in reply to ghost-RCU)
           Post #: 2
    RE: GP Super Stearman - 4/15/2004 12:13:19 PM
    pettit
    Status: offline
    I printed out the instruction manual from the GP web site and they used an OS 120 single.
    And, they provide a neat little plywood box to fasten to the motor mount to put the 18 ounces of lead into, which was needed to balance the plane.
    It's all there in black and white, right in the manual.
    At least they told you to plan for it, not like some other manufacturers, who never mention that you have to add a ton of weight to balance your completed model.
    The Enya, probably heavier than the OS, will require less lead.
    The completed plane, however, reportedly weighed less than 14 pounds dry.
    _____________________________
    Dick Pettit
    Associate Editor, R/C REPORT Magazine
    "You Can Buy Better,
    But You Can't Pay More"
    (in reply to rc-sport)
           Post #: 3
    RE: GP Super Stearman - 4/15/2004 12:49:23 PM
    Don M.
    Status: offline
    Sounds like an ideal candidate for a small gasser !!!!!!
    (in reply to pettit)
           Post #: 4
    RE: GP Super Stearman - 4/15/2004 1:19:11 PM
    P-51B
    Status: offline
    quote:
    ORIGINAL: Don M.
    Small...like in 50cc?!!
    Actually, I wonder if a G-38 (have it on hand) work. I think if someone chose to go with a four cycle, the Saito 170 R3 makes a better choice than a 1.20 single.
    In order to think "outside the box", one must first accept there IS a box.
    (in reply to Don M.)
           Post #: 5
    RE: GP Super Stearman - 4/15/2004 2:10:37 PM
    P-51B
    Status: offline
    quote:
    ORIGINAL: ghost-RCU
    When you get it, could you measure the cowl diameter, please? I'm thinking of getting one of these, but would like to go with a gas engine, and want to see what may fit without cutting holes.
           Post #: 6
    RE: GP Super Stearman - 4/16/2004 1:14:18 AM
    ghost-RCU
    Status: offline
    I should have it the middle of next. I'll measure the cowl and post it here.
    (in reply to P-51B)
           Post #: 7
    RE: GP Super Stearman - 4/16/2004 1:17:32 PM
    P-51B
    Status: offline
    quote:
    ORIGINAL: ghost-RCU
    Thanks!
           Post #: 8
    RE: GP Super Stearman - 4/16/2004 6:54:27 PM
    Mike Bogh
    Status: offline
    I'll just bet the G-38 would be perfect!
    Best to you all,
    Mike
    In memorium
    Art Grabow Sr. AKA Grnbrt..RIP mah Brother
    (in reply to P-51B)
           Post #: 9
    RE: GP Super Stearman - 4/16/2004 6:57:38 PM
    mancha
    Status: offline
    looking forward to get the info as well, thanks.
    mancha
    (in reply to Mike Bogh)
           Post #: 10
    RE: GP Super Stearman - 4/17/2004 9:49:59 AM
    Jimmy Bananas
    Status: offline
    Yep..A G38 will fit in it....LHS just got one in today..looks like a vreg good kit...I'll get mine later...
    (in reply to mancha)
           Post #: 11
    RE: GP Super Stearman - 4/17/2004 2:05:16 PM
    WILDMAN 420
    Status: offline
    I think you will find the G-38 too much for the plane, a G-26 would be my choice for it,if it is only 18 oz added then the G-38 is gonna make it nose heavy.
    (in reply to Jimmy Bananas)
           Post #: 12
    RE: GP Super Stearman - 4/18/2004 8:43:22 AM
    Tailwheel Pilot
    Status: offline
    Would you posts some pics when you get it done.Hope to buy one soon.Thanks
    (in reply to WILDMAN 420)
           Post #: 13
    RE: GP Super Stearman - 4/18/2004 3:05:54 PM
    rongreg13
    Status: offline
    Just got mine from Tower on Saturday. I agree with the prior post that a G38 is too much engine. This is not a very big airframe and it looks like a G26 will be the appropriate engine in power, weight, and size. I've got a B&B G26 that I'm going to use in the plane and I'll post some pictures of the plane with the engine as soon as my wife gets back with my camera. The quality seems first rate, and it has some interesting landing gear. It's not nearly as large as I was expecting, but at least it should fly well without having to spend huge $$ on servos. This is no 3D machine anyways, so I'm expecting it to be a great flier on a G26 and some mid-range servos. I'm going to go with the two aileron servos and slave the second set of ailerons off the first as in the real planes. It even comes with pilots! Not bad for the price, although I would have liked it a bit larger with easier to remove/install wings.
    (in reply to Tailwheel Pilot)
           Post #: 14
    RE: GP Super Stearman - 4/18/2004 5:43:15 PM
    xtraflyr
    Status: offline
    My dad is flying a Pica Waco thats the same size as the Stearman. It has a os 120pumped in it. It flyies very scale like using altitude to gain the airspeed. He's taking the 120 out for another model he's building. Looks like a Saito 150 will be taking it's place. It's awesome being able to make it look real in the air. Not to many people can make them look scale gotta fly them full throttle all the time..
    Later,
    Frank
    www.njjf.org
    www.njjf.freeforums.org
    (in reply to rongreg13)
           Post #: 15
    RE: GP Super Stearman - 4/18/2004 7:57:11 PM
    apalsson
    Status: offline
