RE: GP Super Stearman
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Super Stearman
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: GP Super Stearman
    Page: <<   < prev  38 39 [40] 41 42 43 44 45 46 47   next >   >>
    Login
    RE: GP Super Stearman - 11/21/2007 1:06:45 PM
    TomCrump
    Status: offline
    quote:
    ORIGINAL: summerwind
    just wanted to point out something about this airplane and using a 1.20 four stroke..............there was one at my field this last Sunday, it had an older style OS 1.20 on it. this engine powered this thing like it was a typical sport plane............had more than enough power even at 1/2 throttle.
    i can't imagine why anyone would put a big gas motor on it and spoil the characteristics of the bird by adding all the extra wieght, not to mention the vibration.
    To each his own.
    Since the SS, powered with a 1,20 foure stroke, requires added nose weight, I'd prefer to add the this weight in the form of the addittional power that a gasser provides.
    _____________________________
    Tom C
    (in reply to summerwind)
           Post #: 976
    RE: GP Super Stearman - 11/21/2007 3:24:53 PM
    Flyboy1958
    Status: offline
    I have a G26 on mine and it's perfect. No added extra weight, and flys very realistic.
    (in reply to TomCrump)
           Post #: 977
    RE: GP Super Stearman - 11/21/2007 4:07:37 PM
    summerwind
    Status: offline
    quote:
    ORIGINAL: TomCrump
    To each his own.
    this is totally untrue....................mine has a FT1.60 twin on it and it came out nose heavy........had to move both batteries well behind the wing.
    2 others i've seen with 1.20's have balanced perfectly. several people here and 1 reviewer who used 1.20's also did not need added nose wieght. there was a post somewhere that pointed out that the added nose wieght came from using a .91 four stroke.........mainly a carry over from the manual for the military version.
    the point i am trying to make is that if someone that doesn't know any better reads this thread, they'll end up putting a monster of an engine in this plane when they don't need to.
    i too was having doubts about the engine size as well, but after seeing this plane fly with an "OLDER" version of the OS 1.20 swinging a 16x6, and no nose wieght added, i can honestly say to those thinking about this plane, to go ahead with a 1.20 and be prepared to have a blast................
           Post #: 978
    RE: GP Super Stearman - 11/22/2007 9:30:47 AM
    TomCrump
    Status: offline
    Point well taken, summerwind.
    I'm making a little progress on my SS. Modelling time is hard to come by, as I'm in the process of remodeling my bathroom. I now have the wings mounted. Hope to find a little time to work on the Stearman over the long holiday weekend.
    Tom C
           Post #: 979
    RE: GP Super Stearman - 11/23/2007 11:42:54 AM
    telejojo
    Status: offline
    I put a G-20 in mine and I don't need to use the weght box.I hope to maiden it sat. if the weather holds out........
           Post #: 980
    RE: GP Super Stearman - 11/23/2007 2:40:21 PM
    rexracer
    Status: offline
    I have a question for anyone who has a Saito, or other metric motor on this thing. I'm having trouble putting the spinner on. I bought a spinner adaptor, but it's too long to let the spinner seat aganst the backplate. Anyone know where I can get a short (1/2" to 5/8" adaptor for my Saito? it's 8mmx1.25. the one i bought was about 7/8" to 1" long with the split cone end as a jam nut. I would have cut it down, but there are only 1/8" of threads for the spinner bot, and I would need to cut off 3/8" minimum.
    Club Saito member #173
    (in reply to telejojo)
           Post #: 981
    RE: GP Super Stearman - 11/27/2007 12:48:11 AM
    bucho
    Status: offline
    did some one have the military version? how it do it?
    (in reply to edkoz)
           Post #: 982
    RE: GP Super Stearman - 1/2/2008 9:20:27 PM
    tyler2
    Status: offline
    Would a Zenoah G20ei work well in the Stearman ?
    (in reply to bucho)
           Post #: 983
    RE: GP Super Stearman - 1/2/2008 10:33:35 PM
    zdsh13
    Status: offline
    quote:
    ORIGINAL: rexracer
    Dave Brown spinners also has prop nut adaptors in long or short versions, I needed one for my Saito 125 arrangement. I would imagine any hobby store would stock this item.
    (in reply to rexracer)
           Post #: 984
    RE: GP Super Stearman - 1/2/2008 11:27:12 PM
    telejojo
    Status: offline
    My g20 works just fine.It has more than enough power although not enough for unlimited vertical it will do loops and hamerhead stalls just fine.It probably flys pretty close to scale.
    (in reply to tyler2)
           Post #: 985
    RE: GP Super Stearman - 1/2/2008 11:29:48 PM
    Flyboy1958
    Status: offline
    I have the G26 in mine and it's perfect. I have a smoke system hooked up to it as well. I flys very realistic, so I'm sure the G20ei would be a perfect choice.
    (in reply to zdsh13)
           Post #: 986
    RE: GP Super Stearman - 1/2/2008 11:58:46 PM
    aircraftusfragmentum
    Status: offline
    I finaly got mine finished, havent flown it yet due to weather. 14 pounds 6oz with skywriter pump and Brillelli 26.
    (in reply to Flyboy1958)
           Post #: 987
    RE: GP Super Stearman - 1/3/2008 1:15:56 AM
    Flyboy1958
    Status: offline
    It can be a little touchy on take off, bring the power up steady until it gets rolling 20 feet or so, then bring the power up and the tail will pop right up. Just be ready to use the rudder and also be ready to abort the take off. Landing you have to keep the power up a little since it is a heavy airplane, but it lands real nice, it does like to bounce if you don't have the right airspeed on landing, but it's easy to get the hang of it. It is really a cool looking airplane in the sky!
    (in reply to aircraftusfragmentum)
           Post #: 988
    RE: GP Super Stearman - 1/3/2008 1:24:12 AM
    Status: offline
    I put the 4.5" pnumatic wheels on it to help keep the bounce down. The ones that came in the kit seemed a little hard.
           Post #: 989
    RE: GP Super Stearman - 1/3/2008 2:55:55 AM
    Flyboy1958
    Status: offline
    I did the same thing, it does help.
           Post #: 990
