RE: GP Super Stearman
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Super Stearman
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: GP Super Stearman
    Page: <<   < prev  44 45 [46] 47 48 49 50 51 52 53   next >   >>
    Login
    RE: GP Super Stearman - 5/30/2008 11:55:52 PM
    Shubova
    Status: offline
    rexracer,
    I noticed that you are using the 4 servo setup. How is that working for you...any problems to speak of?
    (in reply to rexracer)
           Post #: 1126
    RE: GP Super Stearman - 5/31/2008 1:03:48 AM
    rexracer
    Status: offline
    Works great with std. 3004 ball bearing servos. Roll rate is at least 2 revs per second on the specified high rates, maybe even 3. If I wass to build another, or if I need a new top wing in the future, I would put the Y connector inside the wing, and put the exit hole to the side near the cabane strut. As it is, I think I hid it pretty well with white vinyl tape.
    _____________________________
    Club Saito member #173
    (in reply to Shubova)
           Post #: 1127
    RE: GP Super Stearman - 5/31/2008 12:29:51 PM
    Jim Henley
    Status: offline
    Thank you for the information, I'll check out the post you referred me to.
    Thanks again !
    Jim,
    WACO Brotherhood #3
           Post #: 1128
    RE: GP Super Stearman - 6/15/2008 12:06:33 AM
    Shubova
    Status: offline
    For those of you who used the Saito 150 in the Stearman…what muffler did you use? The stock muffler hits the firewall.
           Post #: 1129
    RE: GP Super Stearman - 6/17/2008 4:39:13 PM
    Shubova
    Status: offline
    Hi,
    Who is using a on board Electronic Ignition System. I'm concidering using one. Who makes a good one?
    Shubova
           Post #: 1130
    RE: GP Super Stearman - 6/17/2008 4:58:50 PM
    Shubova
    Status: offline
    Oops! I meant an on board remote glow plug starter that uses a on board battery. I'm using a Satio 150 4 stroke. Anyone know of a good one?
    Shubova
           Post #: 1131
    RE: GP Super Stearman - 6/17/2008 8:02:42 PM
    freeonthree
    Status: offline
    Once ya go gas, you'll never go back... hint hint
    http://www.youtube.com/watch?v=vyvd2qmcobw
    I dont crash, I just land hard
           Post #: 1132
    RE: GP Super Stearman - 6/17/2008 8:40:19 PM
    Capt. Ron
    Status: offline
    I just got mine! Turned up the heat on my iron and had all the wrinkles out in about one hour. I'm going to try to get replacement tire from Tower. I think the Dubro 4" low bounce should work good. The tires that came with it bounce like a Super Ball! I ordered a Brillelli 47cc gas engine. More power less weight. It will give me a little extra kick in the pants when I need it. I will all so be installing smoke.
    (in reply to freeonthree)
           Post #: 1133
    RE: GP Super Stearman - 6/17/2008 8:50:25 PM
    freeonthree
    Status: offline
    When you land, you have to slow that puppy down. If you stall it at the ground, it won't bounce at all. In my video, in the above post, im still using the stock foam wheels. Im not going to replace them until there wore out, but yes, they are pretty cheap.
    Landing is the hardest part of this hobby, and you cannot practice it too much. I probably land at least 10 times per flight. Landing is my favorite part of this hobby.
    (in reply to Capt. Ron)
           Post #: 1134
    RE: GP Super Stearman - 6/17/2008 11:10:10 PM
    Jim Henley
    Status: offline
    Shubova,
    A couple of pages back one of the fellows had some shots of the McDaniels RC glow driver. I have the Mcd 466 ordered for my Pica WACO, if it works out
    I'll probably order another one (with out the wall charger) for my Stearman. Have you flown your Stearman with the 150 yet?
    Jim,
    WACO Brotherhood #3
           Post #: 1135
    RE: GP Super Stearman - 6/17/2008 11:36:30 PM
    Tony V.
    Status: offline
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRYK2&P=SM
    This is the one I have for my Y.S. 140..but have not tried it yet...
    Tony, AMA 120246
    WACO Brotherhood #71
    (in reply to Jim Henley)
           Post #: 1136
    RE: GP Super Stearman - 6/18/2008 2:49:53 AM
    Shubova
    Status: offline
    Thanks for all the info guys.
    No I have not flown my Stearman (with Saito150) yet but a couple of weeks ago I went to a scale fly in at a local club. There was three Super Stearmans there. Two with oversized engines, one had a Saito 3 cylinder. I don’t remember what the other one was. They both said it was too much power. The other was using a Saito 150. The owner with the 150 said he loved it. It had all the power you would want or need and by the flights I saw it seemed that way. He also said he didn't have to use the box for extra weight. He used very little weight to balance it.
    Shubova
    (in reply to Tony V.)
           Post #: 1137
    RE: GP Super Stearman - 6/18/2008 7:41:07 AM
    Shubova
    Status: offline
    Hey guys,
    Does anyone have any good (close up) pictures of how they installed the turtle deck? The pictures in the instructions don’t show much detail.
           Post #: 1138
    RE: GP Super Stearman - 6/18/2008 7:49:22 AM
    freeonthree
    Status: offline
    I'll take one for you now, hold on.
           Post #: 1139
