w8ye
OH, USA Status: offline
To my knowledge, those old tractors would run on this distillate without any modification to the carb. They started and ran on the raw distillate white gas. My dad used to make me use it in the lawn mower when I was a kid. By the mid 50's, the first run, raw gas became hard to get so he started buying regular leaded gasoline. Life got easier from a lawn mowing point of view. The B&S mower engine never did wear out but the rest of the mower did. The reason for the change is that, this last time, he was given mineral spirits instead of white gas in his 5 gallon can at the service station. The B&S would start and run on mineral spirits but just had no power. The mineral spirits didn't vaporize very well in the Coleman lantern either. In today's time, with the catalytic fractionation techniques now in use, I doubt if you could classify Coleman fuel as just white gas? Though the flash point and vapor pressures are similar, that's all you get. Though liquid fossil fuel specs are pretty much the same, who knows what it is in actual chemical analysis? The octane rating is less than 80. I see people using it in their gas model engines sometimes and the engines seem to operate fine. The main incentive for use is that it doesn't have a significant smell. Enjoy, Jim
_____________________________
I've attended the CutFinger Institute of DirtNap University for years but never did graduate.... Club Saito Member #7 Original AMA #31261
