RE: Anybody seen the new E-Flite Tribute or Ultimate profile?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Tribute EP 3D Profile
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: Anybody seen the new E-Flite Tribute or Ultimate profile?
    Page: <<   < prev  1 2 3 4 5 6 [7]
    Tower Hobbies Today's Special Offer! Brands Products
    Login
    RE: Anybody seen the new E-Flite Tribute or Ultimate pr... - 10/13/2004 4:05 AM
    3dandpatternflyer
    Score: 100
    Last Login: 8/9/2010
    Status: offline
    Well,
    I've heard from a lot of people on RCGroups and even a club member say the Tribute flies like junk. They say the fusealge just starts shaking and it won't roll good and the wings flap like a bird. Experinces anyone???
    TTYL,
    Andrew T.
    _____________________________
    www.3DFoamy.com Rules!
    Hide Signatures
    (in reply to Mike Bogh)
           Post #: 151
    RE: Anybody seen the new E-Flite Tribute or Ultimate pr... - 10/13/2004 5:09 AM
    Iceman30
    Score: 100
    Last Login: 10/8/2007
    Status: offline
    I can run full speed with brushless on 11.1 volts with 12-6 prop and NO flutter, no shake ON THE ULTIMATE..have heard the Tribute doesn't have great roll rate. no flapping on the ultimate...
    Hide Signatures
    (in reply to 3dandpatternflyer)
           Post #: 152
    RE: Anybody seen the new E-Flite Tribute or Ultimate pr... - 10/13/2004 11:14 PM
    Emmitt
    Score: 100
    Last Login: 1/1/2010
    Status: offline
    Flew my new tribute 3 flights this weekend and loved it. The balsa elev. joiner broke while building so it was replaced with hardwood. running the park 370, CC 25 esc TP 860 mah 3 cell batteries. More than enough power. No shaking or flutter, but the wings did flex some. This is my first electric, and I was surprized at how much power it had.
    Hide Signatures
    (in reply to Iceman30)
           Post #: 153
    RE: Anybody seen the new E-Flite Tribute or Ultimate pr... - 10/14/2004 2:48 PM
    kennyandannie
    Score: 100
    Last Login: 8/17/2010
    Status: offline
    I didn't read this whole thread, but has anyone tried this combo, this is the gear I am putting in my Ultimate.
    Hacker B20-15L
    Phoenix 25
    HS-55's
    Apogee 830 3-cells
    Thanks for your input, this should pull it around fairly well, ya' think?
    Ken
    P.S. I think the packs are 830's, maybe 870's, I don't remember.
    Hide Signatures
    (in reply to Emmitt)
           Post #: 154
    RE: Anybody seen the new E-Flite Tribute or Ultimate pr... - 12/26/2004 3:49 PM
    red_z06
    Score: 100
    Last Login: 5/14/2012
    Status: offline
    Get 4 12" small diameter carbon rods or tube and pierce through the canopy area and poke it through right next to leading carbon tube on the wing so you can anchor the carbon rod to it with epoxy or ca glue. The end result is a diamond shaped wing brace. There is ZERO wing flex. If you already have flown yours without, they you will think you are flying entirely different plane.
    My setup:
    Axi 2212/34
    APC 12x6 Slo Flyer Prop
    3cell 1050mah Apoge Li-Po (Kokam with high C discharge were anounced so will switch to it soon)
    Castle Phoenix 10 ESC
    4 Hitec HS-55
    Flight Time 10min
    Mix Flapperons for crazy tight loops (more like tumbles) and Spoilerons for sharp walls and parachute.
    JustinJee.com
    Hide Signatures
    (in reply to kennyandannie)
           Post #: 155
    RE: Anybody seen the new E-Flite Tribute or Ultimate pr... - 12/26/2004 4:18 PM
    kennyandannie
    Score: 100
    Status: offline
    Red,
    I've heard a lot about those Axi motors, I've been using the Hacker on all of my foamies.
    I just switched to a HiMaxx outrunner for my Tensor 4D, because of the weight.
    I'll try that brace method. I'm assuming there will be 2 per side, like an X, correct?
    Thanks for the idea
    Ken
    Ken Thompson - Team Black Magic - Team DragonFire
    Fellowship of Christian Modelers
    Hide Signatures
    (in reply to red_z06)
           Post #: 156
    RE: Anybody seen the new E-Flite Tribute or Ultimate p... - 12/30/2004 3:15 AM
    E*nealio
    Score: 100
    Last Login: 1/2/2011
    Status: offline
    6!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Is it supposed to make that noise?
    Hide Signatures
           Post #: 157
    RE: Anybody seen the new E-Flite Tribute or Ultimate p... - 12/30/2004 6:52 AM
    red_z06
    Score: 100
    Status: offline
    Kenny:
    Yes 2 per side. It should resemble a diamond shape looking from the front. If you have done that, can you tell me how it flies?
    JustinJee.com
    Hide Signatures
    (in reply to E*nealio)
           Post #: 158
    RE: Anybody seen the new E-Flite Tribute or Ultimate p... - 12/30/2004 2:45 PM
    kennyandannie
    Score: 100
    Status: offline
    I haven't done it yet, I'll let you know. I've been playing with my Tensor so much, I put the Ulti on the back burner.
    Ken
    Hide Signatures
           Post #: 159
    RE: Anybody seen the new E-Flite Tribute or Ultimate p... - 12/30/2004 5:33 PM
    red_z06
    Score: 100
    Status: offline
    Kenny:
    Above mentioned (diamond) is for Tribute. For Ultimate, you can use 2 longer rods similar to your Tensor. So it would look more like a "X" with center going through the canopy area (vertically centered) and ends connecting at the each base of the wing strut.
    JustinJee.com
    Hide Signatures
           Post #: 160
    RE: Anybody seen the new E-Flite Tribute or Ultimate p... - 12/30/2004 9:12 PM
    SLINGSHOT-RCU
    Score: 100
    Last Login: 2/11/2009
    Status: offline
    Anyone using Park 370 Brushless Motor 5400KV on there tribute . This is my first electric any pics of your setup? Thanks Eddie
    EDDIE
    Hide Signatures
           Post #: 161
    RE: Anybody seen the new E-Flite Tribute or Ultimate p... - 12/31/2004 1:52 AM
    kennyandannie
    Score: 100
    Status: offline
    Got it Red,
    That sounds like it would work much better. I couldn't quite get the picture of the diamond shape on a bi-plane.
    I'll be making a trip to the LHS tomorrow, I'll pick up some CF rod.
    Ken
    Hide Signatures
           Post #: 162
    RE: Anybody seen the new E-Flite Tribute or Ultimate p... - 1/1/2005 3:43 AM
    patrnflyr
    Score: 100
    Last Login: 5/21/2012
    Status: offline
    Need some help on the Tribute. This is my first post to the electric site and we've only been flying electrics for 3 weeks. I am trying to learn the electric lingo, but your help would make me feel more confident in our choices. I like the way the Tribute flies, but am getting tired of the noise and fragility of the gear box (and the plane for that matter). We are willing to give up on the 370 brushless/gearbox combo and switch to some kind of outrunner motor (Axi?) if you can give us a recommendation. I forgot to mention, no landing gear and flown off our backyard's grass. The landing gear was a joke... If you have another airframe that would be more durable for this hardware including the motor/gearbox combo, that would be okay too. We have a CC25 ESC, HS55's, Eflite 1200 11.1 batt's and Triton charger. Thanks for your advice in advance...
    John S. Johnson
    Lubbock, TX
    PS. My son and I like electrics so much that in the last three weeks, our inventory went from nothing to a tribute, 2 mini funtanas, and a tensor!!!
    Hide Signatures
           Post #: 163
    RE: Anybody seen the new E-Flite Tribute or Ultimate p... - 1/1/2005 4:01 AM
    red_z06
    Score: 100
    Status: offline
    Patrnflyr:
    For tribute, any outrunner motor with specs similar to Axi 2212/26 or 2212/34 will do. I fly mine with 2212/34 with apc 11x7 or 12/6 slo flyer prop. 2212/26 will run good with 11x4.7 slo flyer. For esc, use castle creations phoenix 25 for 2212/26 and phoenix 10 for 2212/34.
    Both motor with the mentioned props will work good with 3cell 1000mah lipo with mininum of 10c dischage or 10A ****inuous discharge.
    I prefer Castle creations over Jeti for flexibility of programming setups.
    JustinJee.com
    Hide Signatures
    (in reply to patrnflyr)
           Post #: 164
  • Read Full Review
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
    0.422RCU1
