RE: Impact
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> RE: Impact Page: <<   < prev  22 23 24 25 26 27 28 29 30 [31]
Login
RE: Impact - 9/13/2006 3:14:42 PM
jlkonn
Status: offline
Here are the weights of my recently received Impact.
It was weighed on a food scale before any of the cutouts were made and with no accessories or subassemblies attached.
There may have been a few pieces of the masking tape still attached:
Weights are in grams-
Fuse only 736
Canopy 102
Chin 68
Rudder 88
R.stab 112
L.stab 113
R.wing 457
L.wing 463
JLK
_____________________________
A goal without a plan is just a dream.
AMA 97605
(in reply to tggilkey)
       Post #: 751
RE: Impact - 9/13/2006 6:22:58 PM
tggilkey
Status: offline
Joe --
The hinge line sealing material weighs 3 grams per foot with the protective paper still attached. I weighed a strip of the paper (1 foot long) removed from earlier use and it wouldn't register...
Good Luck!
Tom
(in reply to jlkonn)
       Post #: 752
RE: Impact - 9/14/2006 11:25:47 AM
vellum2
Status: offline
Cool - Thats for the info Tom. I stripped a bunch of weight out of mine so I'm not worried about a few grams here or there anymore ;-)
       Post #: 753
RE: Impact - 9/14/2006 11:27:02 AM
vellum2
Status: offline
Whoa - I can type - What I meant to say was "Thanks" Ugh - too early..
(in reply to vellum2)
       Post #: 754
RE: Impact - 9/28/2006 1:01:08 AM
vellum2
Status: offline
Well Northeast Sailplane has a wonderful website! thanks for the info Tom. I ordered the tape so hopefully my snaps will improve too. I spoke too soon earlier - Can you believe I missed just about every snap during the last contest! I swear I was hitting them all day long in practice... I hate when that happens! Doh.
Joe W.
       Post #: 755
RE: Impact - 1/15/2007 3:19:49 AM
flying martin
Status: offline
any one have an impact manual
(in reply to Joe Kelley)
       Post #: 756
RE: Impact - 1/15/2007 7:32:37 AM
f3a05
Status: offline
It used to be on the Comp-Arf website.If it's not still there,
I think I can email it to you--it's a pdf file,whatever that means.
(in reply to flying martin)
       Post #: 757
RE: Impact - 1/16/2007 12:14:09 AM
iflyrctoo
Status: offline
The manual can be found here.
http://www.composite-arf.co.uk/ImpactTips.htm
Joe Dunnaway
(in reply to f3a05)
       Post #: 758
RE: Composite ARF Impact - 3/26/2007 1:00:42 AM
Lt Oneman
Status: offline
Hey this is one big post here. I'm fixing to get a Composite ARF Yak55 and my question is Composite ARF.com the ony ones making the Composite ARF?
They are about the only site i can find. Any help would be great.
(in reply to ExFokkerFlyer)
       Post #: 759
RE: Impact - 2/9/2008 10:32:08 AM
dapan
Status: offline
hi
my impact is 5100gr and i am thinknig to cansel the cf tunel to go at 5000gr can anyone tell me how importand is the tunnel for the plane?
thanks
dapan
(in reply to Lt Oneman)
       Post #: 760
RE: Impact - 2/19/2008 3:34:27 AM
F-4
Status: offline
Am building an Impact. Alignment giving me fits as I keep chasing fusalage hole alignment issues. Is this thread still alive???
John
(in reply to dapan)
       Post #: 761
RE: Impact - 2/19/2008 10:32:02 PM
tggilkey
Status: offline
Hi Jon --
As far as you and I are concerned it is! I'm building one also -- a second one. Is there a specific alignment question you have? I know some have said the holes worked and others that used them more as “suggestions.” I tended (with the first one) to use them as suggestions -- actually for the wing, only used the main spar tube holes. For the stab, I used both spar and anti-rotation pin holes -- but with adjustments as necessary. Prior to this decide whether you are going with incidence adjusters or the stock setup -- open the holes for what you will need. For the main spars for wing and stab make one side's holes a good fit for the socket material and don't mess with it -- the other side will be the floater for trammeling adjustments. Basically a good setup (which I gleaned from others in this thread) was this:
On a flat table (important), have the front bottom of the fuselage (no engine, no engine cowl) resting (just touching) the table. Yeah, the fuselage is round so it will have to be stabilized -- I used a fixture which had a base with 2 threaded uprights; a cross piece between the uprights whose height is adjustable by means of washers and wing nuts. The height is adjustable and because each side is adjustable independently the vertical fin angle relative to the table top can be adjusted also. Prop the tail up from the table 45mm; then adjust the fixture holding the nose such that the fuselage bottom (right at the joint where the engine cowl would be) just touches the table.
Mark the location of the support fixture cross piece on both the fuselage (both sides) and on the cross piece (for repeatability...); also make your support block just slightly wider than fuselage width at the tail -- you may need the real estate for setting/measuring incidences later on. I tacked the block to the bottom of the tail after bumping the setup off the block twice... and having to start over with the setup. Hence the marks and tack job...
Get the fuselage setup so the tail is propped up 45mm, the front of the fuselage minus engine cowl just touching the table and the fin vertical to the table.
Now you are ready to set the alignment of the wing relative to the fuselage. Assemble the wing panels on the tube (and fuselage) and adjust the other side (the “floater”) until aligned as viewed from the back and from the top. Make the wing tips equidistant from a point on the bottom of the fuselage (just in front of that 45mm block). Come up with something repeatable – I used a small (1/4” wide) metal tape measure – sacrificed it years ago for this purpose – drilled a pivot hole on the center of one end and held it to the center of the fuselage at the back with a #2 sheet metal screw. Either the hole gets covered by the tail wheel or filled when done. The tape doesn’t stretch like string and with consistent pressure applied doesn’t sag much. There are better methods but I haven’t taken the time to put them together. Check out Bob Noll’s Perfect Alignment series.
When doing this stage of the alignment keep the surfaces close to zero so your other measurements don’t get skewed. Judicious use of tape can help hold incidence on one side. Sometimes the tube and socket fit is enough. I set the initial incidences at 0 by measuring LE and TE the same distance out from the fuselage or in some cases by a line established on the fuselage (drawn on removable tape of course…). I think I used 1 turn of positive incidence on the Gator adjusters (with the adjusters at 6” centers from the tube). After adjusting the screws, check the TEdges for agreement and same for Ledges. Obviously the differences should be the same. I was quite pleased with the way the first one trimmed out.
Digest this and many of the postings in this now longer thread… Look for things from PeterP, MalcolmH, David Gibbs and some others like Eric Henderson. I borrowed liberally from them during my build. Their advice was sound.
Good luck with your build and feel free to either post more questions or PMail me.
Tom
(in reply to F-4)
       Post #: 762
RE: Impact - 2/22/2008 12:26:44 PM
Jeff Boyd 2
Status: offline
I have recently finished an Impact and it fly's great . . still have more trimming to do (I guess this is really an ongoing thing ).
It is the plain white / red version and was originally built (by someone else) for Electric. I converted it to glow, did some modifications and repainted it. It has OS140RX / Aeroslave CF pipe / Bolly gear and spats / JR and weighs 4.75kg (just under 10 1/2lbs).
Currently it is carrying a little down trim on the elevators which bothers me. I am playing with the wing adjusters, thust, and CG at the moment and it is getting better BUT if I built another, I would fit stab adjusters for sure. I am still considering performing some "surgery" and fitting them even now.
Anyhow . . great flying plane, for sure ! !
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Jeff Boyd 2 -- 2/22/2008 12:33:34 PM >
(in reply to F-4)
       Post #: 763
RE: Impact - 2/22/2008 1:09:17 PM
