Composite ARF Impact    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> Composite ARF Impact
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Composite ARF Impact - 4/17/2004 11:04 PM
ExFokkerFlyer
Score: 100
Last Login: 5/18/2013
Status: offline
Was just cruising some websites this morning and saw this new plane offered by Composite ARF. Looks like a revamped and modified Revolution Pro at a couple hundred bucks cheaper. 899 for the stock paint job or $739 for plain red and white. Anybody have any info on this? It looks pretty good and I like the idea of a composite airframe, even though the finish quality can be hit or miss at times.
Hide Signatures
       Post #: 1
RE: Composite ARF Impact - 4/18/2004 1:15 AM
Pro pattern
Score: 100
Last Login: 2/5/2013
Status: offline
Hello everyone,
I have just visit Composite ARF and I have seen the IMPACT.
It’s a very beautiful plane, and full Composite.
Now that is very impressive and IMPACTing indeed.
I will have to consider this fore a Second plane. ”Back-up plane”
Thanks for the Info on this plane, I was thinking that they will be selling a
new plane soon because the Revolution Pro was on sale.
Danny
_____________________________
Nobody is perfect, I am nobody .............. 3rd place, is just 2nd best loser
Hide Signatures
(in reply to ExFokkerFlyer)
       Post #: 2
RE: Composite ARF Impact - 4/20/2004 1:42 AM
PepsiMike
Score: 100
Last Login: 3/11/2013
Status: offline
Interesting.
Nice to see another 2M ARF out there worthy of consideration. Price is in the ballpark as well.
Hide Signatures
(in reply to Pro pattern)
       Post #: 3
RE: Composite ARF Impact - 4/20/2004 2:18 AM
tph1
Score: 100
Last Login: 5/23/2010
Status: offline
what site is it on?
Team Hindsight Charter Member
Hide Signatures
(in reply to PepsiMike)
       Post #: 4
RE: Composite ARF Impact - 4/20/2004 3:03 AM
Pro pattern
Score: 100
Status: offline
Here is the Web-site: www.composite-arf.com
For direct access; www.composite-arf.com/ar/Catalog?cat=27
Danny
Hide Signatures
(in reply to tph1)
       Post #: 5
RE: Composite ARF Impact - 4/20/2004 9:52 AM
ExFokkerFlyer
Score: 100
Status: offline
It does look interesting. I was planning on maybe a Focus 2 for next season, but the Impact has got me intrigued. I would like to see one, or maybe hear from somebody who has flown it or seen it fly. I remember reading something about Jason Shulman flying a modified, slightly or otherwise, Revolution Pro... maybe this was the result?
Hide Signatures
       Post #: 6
RE: Composite ARF Impact - 4/21/2004 2:50 AM
JAS
Score: 111
Last Login: 4/24/2013
Status: offline
The Impact has all the changes plus from what I had discussed with Andreas for a "new" pattern plane. The current Rev-Pro I have electrified is a standard Rev-Pro. I have a white one due in this week that I will probably cut the fillets off of. I may also have a fiberglass canopy made instead of the clear one that comes with the kit. Other than that, this white one will be stock. I have ordered an Impact, but with a due date of Late May, I'm not sure if I'll have time to finish it before the NATS/Team Trials. I don't know anything else about the Impact other than what is posted on the site.
Uncle JAS x 2
Shulman Aviation
Check us ^^^ out for US Team stuff
Hide Signatures
       Post #: 7
RE: Composite ARF Impact - 4/21/2004 6:39 AM
ExFokkerFlyer
Score: 100
Status: offline
Thanks for the info, will be looking forward to seeing the Impact once it hits the contest circuit.
What weight is the electric Rev-Pro coming in at?
Hide Signatures
(in reply to JAS)
       Post #: 8
RE: Composite ARF Impact - 4/21/2004 10:30 AM
ExFokkerFlyer
Score: 100
Status: offline
I know the Composite ARF planes are painted in the mold, but if you were to get the basic white and red versions, how would you go about painting them? Is primer necessary, or can you just shoot over it as it comes?
Hide Signatures
       Post #: 9
RE: Composite ARF Impact - 4/22/2004 3:46 AM
quist
Score: 116
Status: offline
Jason,
How are you going to cut the fillets off?
Hide Signatures
       Post #: 10
RE: Composite ARF Impact - 4/22/2004 12:59 PM
AmirN
Score: 100
Last Login: 1/3/2011
Status: offline
Primer is not necessary on the glass fuselages for paint adhesion. As long as the surface, whether glass or gelcoated or pre-primed is scuffed for the paint to grab onto, it'll be fine.....The purpose of primer on the glass fuselages is to high light pinholes and any flaws. Once perfect, the primer can be sanded completley off, however, that may cause more pinholes if you sand into the glass...so, it's better to leave a little primer on so the surface looks translucent and paint......The pre-primed or the gel-coated fuses eliminate a lot of the pinholes and save about two shots of primer, cleaning the gun and sanding. One can even add Monokote (the regular iron-on version attached with the Windex method) as trim, lightly scuff and clear if needed.
I'm curious about this plane's performance.....I'm looking at it too.
Take care,
Amir
Soon to move to Vegas
Hide Signatures
(in reply to quist)
       Post #: 11
RE: Composite ARF Impact - 4/22/2004 2:53 PM
raptor5900
Score: 100
Last Login: 8/13/2009
Status: offline
how much paint would you need for this plane?
Retired
Hide Signatures
(in reply to AmirN)
       Post #: 12
RE: Composite ARF Impact - 4/23/2004 7:19 AM
pizza
Score: 100
Last Login: 9/15/2009
Status: offline
In europe they are putting a zdz40re in these with soft mount, es cf gas pipe, 22X10 prop, makes weight and noise limit no prob, one guy has over 500 maintenance free flights on cheep gas - he says engine is barely broke in - I will try to get pics showing setup.
Hide Signatures
       Post #: 13
RE: Composite ARF Impact - 4/23/2004 9:06 AM
ExFokkerFlyer
Score: 100
Status: offline
A ZDZ powered Impact??? I can't go the electric route yet, though I definetely will want to sometime, but gas would definitely be interesting! I would love to see some pictures of that if you can scrounge some up!!!
Hide Signatures
(in reply to pizza)
       Post #: 14
RE: Composite ARF Impact - 4/23/2004 10:35 PM
nedim
Score: 100
Status: offline
Amir,
How can you be sure about the paint adhesion on a surface that comes out of the mold?
Basically all lay-ups including the painted in the mold ones has mold release residues unless otherwise the surface is cleaned with a solvent which does not effect the paint but cleans the mold release agents.
Therefore, a primer coat is not required but a fine sanding or scuffing procedure is advised before spraying colours on the surface.
Hide Signatures
(in reply to AmirN)
       Post #: 15
RE: Composite ARF Impact - 4/23/2004 11:18 PM
mups53
Score: 105
Last Login: 5/19/2013
Status: offline
I'm interested in the process of spraying in the molds. Are there any websites that illustrate this procedure? TIA, Mike
F3AUnlimited Customer Service
1 800 591 2875
Hide Signatures
(in reply to nedim)
       Post #: 16
RE: Composite ARF Impact - 4/24/2004 1:12 PM
AmirN
Score: 100
Status: offline
Hi Nedim,
I believe I did mention scuffing is necessary for adhesion. And of course I took it for granted that most know about the mold release, so a light liquid soap/water wash prior to scuffing would be ideal for most mold releases, which are PVA over wax....I lay up my glass fuses with just wax and no PVA, so one should know what kind of mold release is used to use the appropriate solvent to remove the mold release....Assuming a substrate is clean of mold release, no primer is needed, just a little scuffing...Primer is to high light flaws in the case of our models.....I use a scotch brite pad for scuffing.
Take care,
Amir
< Message edited by AmirN -- 4/24/2004 10:15:17 AM >
Hide Signatures
(in reply to mups53)
       Post #: 17
RE: Composite ARF Impact - 4/27/2004 11:41 PM
JAS
Score: 111
Status: offline
I'll cut the fillets off with either a knife or saw or both.
Uncle JAS x 2
Shulman Aviation
Hide Signatures
(in reply to AmirN)
       Post #: 18
RE: Composite ARF Impact - 4/28/2004 5:19 AM
lems
Score: 100
Last Login: 12/25/2007
Status: offline
I am curious. What is the reason for removing the fillets? Does it give the plane more drag to even out its speed? Lem
Hide Signatures
(in reply to JAS)
       Post #: 19
RE: Composite ARF Impact - 4/28/2004 5:33 AM
mups53
Score: 105
Status: offline
I'm looking at the pics of the Impact and I can't tell from them that it has the huge fillets that the Rev Pro had. Also Jason the plane already comes with a fiberglass canopy according to the write up on the website. Check out this pic and tell me what you guys think of the fillets. Mike
http://www.composite-arf.com/arf/images/5110001081940512738-impact.001mod.jpg
1 800 591 2875
Hide Signatures
(in reply to lems)
       Post #: 20
RE: Composite ARF Impact - 4/28/2004 7:01 AM
ExFokkerFlyer
Score: 100
Status: offline
If you read his post again, Jason was referring to the Rev Pro regarding the fillets and canopy.
Hide Signatures
       Post #: 21
RE: Composite ARF Impact - 5/21/2004 1:55 PM
NZ Scythe
Score: 100
Last Login: 1/5/2012
Status: offline
Does anyone have one of these models flying yet??
I'm interested but I'd like to read some posts about she flies first.
If I was going to get one I'd get the White/red belly version and use computer cut vinal for the graphics. I have access to a plotter and it makes the job so easy! No paint! no masking! no runs! no flies getting stuck to your model! and best thing is if you want to change the colour scheme a few months later you can just peel it off and do it again! (removable vinal) also the posibility of using solvent based ink printers to get a photo realistic/airbrushed effect is simple. certainly worth looking into.
Hide Signatures
       Post #: 22
RE: Composite ARF Impact - 5/21/2004 7:17 PM
fishgod
Score: 100
Last Login: 6/9/2011
Status: offline
I have one on order. The first shipment is due to hit the USA around the first of June. With the planes being delivered the middle of June.
Regards
Michael
Hide Signatures
(in reply to NZ Scythe)
       Post #: 23
RE: Composite ARF Impact - 6/15/2004 12:00 PM
PeterP
Score: 100
Status: offline
I have just taken delivery of an "IMPACT"
I puchased the white and red version so that I can put my own colour scheme on the model.
I am very impressed with the quality of the kit for the money I have paid. It represents excellent value for money compared to other offerings around.
The kit includes a carbon spinner, carbon wing tube, carbon undercarriage and wheel pants, carbon laminated laser cut formers and really cool wing covers, fuselage cover and tail plane covers.
The design looks good and the fuselage is big and deep (As deep as my Alliance). Weight seems very good as well. I will take some pictures soon and weigh things if your all interested.
Peter
Hide Signatures
(in reply to fishgod)
       Post #: 24
RE: Composite ARF Impact - 6/15/2004 4:14 PM
byoung466
Score: 100
Last Login: 12/30/2012
Status: offline
Im interested in pictures.
Hide Signatures
(in reply to PeterP)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
6.172RCU1
