What plane to get?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-500 Racing >> What plane to get?
Page: [1]
Login
What plane to get? - 6/25/2002 5:46:29 AM
1Jimbo
Status: offline
I know NOTHING at all about Q500 planes so I need help. I need something cheap and easy to build. And fast. I have a TT.36(hot) I want to put on it. What plane should I get?
_____________________________
Ragin Cajun Combat Squadron
my email raptorcombat@yahoo.com
       Post #: 1
What plane to get? - 6/25/2002 6:15:37 AM
PylonWorld
Status: offline
Go to [URL=http://www.pylonworld.com/rc_pylon/q-500/planes/q-500_planes.htm]Q-500 Planes[/URL] for a list of what's available.
For that engine, and given your other specs, I would suggest a Lanier Predator with a (sorry guys, gotta reuse this one ) Hayes AL-25 Long Mount - This .25 to .36 compatible engine mount has the same firewall bolt pattern as the Jett Engineering 4 bolt conforming Q-500 backplate mounts and the Nelson Q-500 backplate mount. This makes it possible to set up a Quickie airframe for multiple classes. Weight shifting will be required since the Slow Quickie engines are significantly lighter than the 428, 424, and APRA engines.
The AL-25 lets you put the engine forward some so that the nose moment doesn't change, and helps in balancing.
A link to the engine mount is on PylonWorld.com at [URL=http://www.pylonworld.com/rc_pylon/q-500/q-500_engines.htm]Q-500 Engines[/URL].
Be aware that there is an "old" Predator and a "New" Predator. Make sure you get the new one, and save yourself some trouble. The new one has a 3/8" (approximately) thick firewall.
How did you find us?
Don Stegall
RCPRO Chairman of the Board
(in reply to 1Jimbo)
       Post #: 2
What plane to get? - 6/25/2002 8:06:28 AM
1Jimbo
Status: offline
I came over from the combat forum. I'm new there too but I have been flying combat for about 10 years. I usually hang out at the **** combat forum, it's pretty big.
I want to give this stuff a try though.
       Post #: 3
What plane to get? - 6/25/2002 9:40:02 AM
PylonWorld
Status: offline
Since you've been flying combat, you're used to some of the more difficult aspects of racing that sport flyers have difficulty adjusting to:
1) Flying in close quarters with other planes.
2) Breaking planes.
3) Wake turbulence
#1 inevitably leads to #2 some of the time. Wake turbulence in the groove is something you get used to with some practice. With the really fast Q-500 and Q40 planes, you can even wind up in your own wake turbulence from the prior lap.
Get yourself a plane and get it in the air. After you get accustomed to the characteristics of the plane, start flying the course, or a simulated course.
Is there a club with any racing in your area? Where are you located?
There are two types of courses. The 2 pole course, and the 3 pole course that is used for AMA sanctioned events. With the 2 pole course, you fly in front of yourself. On the 3 pole course, you fly around yourself. Check out the [URL=http://www.modelaircraft.org/templates/ama/PDF-files/Rulebook/rc-pylon.PDF]RC Pylon Racing Rules[/URL] for course dimensions and race procedures, as well as plane specifications.
Don Stegall
       Post #: 4
What plane to get? - 6/26/2002 3:35:30 AM
1Jimbo
Status: offline
I don't know of any clubs close by that has races but that doesn't mean there aren't any. I'll have to ask around. I'm from southwest Louisiana, Sulphur to be exact. I would guess that there is probably a lot of this going on in the Houston area, that's not very far. Thanks for all the info.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU3
