47" edge 540
Tower Hobbies
Logged in as Guest
  Printable Version
50 Size 3D Profile - RTF
Seller:  DAVIS300
Details:   $275.00   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> 47" edge 540
Page: [1]
Login
47" edge 540 - 4/20/2004 2:02:40 PM
changed
Status: offline
Hey guys,
Great kit, I can't wait to fly-it! I bought it at the Joe Nall last year and have finally gotten around to building it. I have one question there were some 1/16" plywood pieces shaped like the front half of a rib, I searched the instructions and could not figure out what these were for.
       Post #: 1
RE: 47" edge 540 - 4/21/2004 5:15:54 PM
AFSalmon
Status: offline
Brian, I think that is scrap from the laser cut fuselage doublers.
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to changed)
       Post #: 2
RE: 47" edge 540 - 5/26/2004 11:10:39 PM
topflight-RCU
Status: offline
I also want to say that this is a great kit. This is my first profile and I think I am starting to like them better than the other scale aircraft. I do have one question, I have the all wood kit and would like to put in a pull-pull system on the rudder and the elevators, would this cause and problems with the balancing by putting the servos under the hatch? It would be about the same configuration as the Morris TopCap.
(in reply to AFSalmon)
       Post #: 3
RE: 47" edge 540 - 5/27/2004 7:14:41 PM
AFSalmon
Status: offline
Pull-pull cable setup is fine but really doesn't give you any advantage. You may have some balancing problems though as the plane balances almost perfect with stock build and equipment. Removing the tail servos will take quite a bit of tail weight out.
(in reply to topflight-RCU)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU2
