taylorcraft1947
Joined: 12/20/2003 From: Flushing, MI, USA Status: offline
The above picture of the Cedarville plane was taken during the first flight. It was balanced at the rear CG limit and was quite tail heavy, yet it was still controllable. The spoilers were half-way up because, with that weight, it was supposed to be off of the runway at ~6mph! This was way too slow for the tail, as the plane would have been impossible to control. This was done on both of the first two flights. Also, yes, it is the most stable aircraft that I have ever flown, except, well, maybe a telemaster. The stability is no doubt mostly due to the end plates and decently sized horizontal (although, not too big). However, that much stability is not so good in a heavy wind, especially when the plane is lightly loaded. By the way, if the university does not let me have it, I will build another. taylorcraft1947
