RE: MIDWEST AT-6 TEXAN
Tower Hobbies
Logged in as Guest
  Printable Version
Top Flite P-51D Mustang - 1/5 RTC - ARF
Seller:  chase67
Details:   $750.00   |  11/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: MIDWEST AT-6 TEXAN
Page: <<   < prev  1 [2]
Login
RE: MIDWEST AT-6 TEXAN - 6/8/2007 2:46:35 AM
RR24
Status: offline
Does anyone have some pics of when they where building this plane with flaps or some good pics of the flaps after plane was finished, i have a kit i will be starting on in the near future
Thanks Wes
(in reply to JL1)
       Post #: 26
RE: MIDWEST AT-6 TEXAN - 6/27/2007 12:47:51 PM
RBACONS
Status: offline
Does anyone have the recommended throws for the Midwest AT-6. I'm trying to get mine flight ready after 8 years in storage and can not locate my plans or instruction book.
Thanks, Tony
(in reply to RR24)
       Post #: 27
RE: MIDWEST AT-6 TEXAN - 8/6/2007 1:31:31 PM
GX Ame
Status: offline
I am currently researching engines for my Texan. I'm thinking about the G26. Will it fit completely within the cowl? Don't want too much hanging out. I've noticed the Saito 150 might require cut outs.
(in reply to Yellowflier)
       Post #: 28
RE: MIDWEST AT-6 TEXAN - 8/6/2007 1:42:31 PM
carlbecker
Status: offline
It will probably fly well to a bit over powered with the OS 108, Webra 120 or Moki 135 or OS 120, Saito 125 or even the Saito 170. The three cylinders sound great and add smoothness and weight up front. Some day when my build bench is open I would like to to a 15-17 pound 80" Vought Kingfisher with the Saito 170. Laser makes a short 150 which would probably fit in the cowl like the 2 strokes.
Carl
(in reply to GX Ame)
       Post #: 29
RE: MIDWEST AT-6 TEXAN - 8/6/2007 3:14:16 PM
TLH101
Status: offline
Keep in mind on the Midwest AT-6, with a G-26 you may need some nose weight. They balance almost perfect with a G-38.
_____________________________
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
(in reply to carlbecker)
       Post #: 30
RE: MIDWEST AT-6 TEXAN - 10/7/2007 5:21:57 PM
azad
Status: offline
I have mounted moki 210 on my midwest at6, althought the head sticking out olf the side it looks very beffy. since I can not find the plan for this bird, Can someone tell me where the center of gravety is? Please help. Thank You
(in reply to TLH101)
       Post #: 31
RE: MIDWEST AT-6 TEXAN - 11/13/2007 11:09:48 PM
gunnyed
Status: offline
I was building the Midwest AT-6, and in the of the build I had to move. Now I can't find my instruction manual. Does anyone have the instruction manual they can sell at a reasonable price.
Gunny Ed
(in reply to JL1)
       Post #: 32
RE: MIDWEST AT-6 TEXAN - 11/14/2007 12:34:54 AM
meatball1
Status: offline
THE CENTER OF GRAVITY ACCORDING TO MY FUSELAGE SHEET PLAN IS 4.5 " FROM LEADING EDGE , GIVE OR TAKE A HALF INCH . THAT PUTS IT JUST BEHIND THE WING BOLTS ! HOPE THAT HELPS !
(in reply to azad)
       Post #: 33
RE: MIDWEST AT-6 TEXAN - 11/14/2007 12:53:30 AM
meatball1
Status: offline
quote:
ORIGINAL: RBACONS
Thanks, Tony
HEY TONY , THE PLANS INDICATE THAT THE ELEVATOR IS 3/4 UP AND 3/4 DN ; THE AILERONS OR 7/8 UP AND 1/2 DN ; RUDDER IS 7/8 LEFT AND 7/8 RIGHT ! BY THE WAY THAT'S MEASURED AT THE WIDEST POINT OF CONTROL SURFACE ! HOPE THAT HELPS .
(in reply to RBACONS)
       Post #: 34
RE: MIDWEST AT-6 TEXAN - 11/17/2007 8:54:40 PM
WarbirdAirRacer
Status: offline
Just checking and wanted to say if you want to sell your T 6 let me know! or anyone else that has one they wanna sell I would be happy to pay $$$$$ for what its worth!....
my ole man use to have one with a BGX 3500 in it and damn did it fly good!!!
Tat-Tude 379
(in reply to meatball1)
       Post #: 35
RE: MIDWEST AT-6 TEXAN - 12/22/2007 8:31:24 PM
bladerunner1955
Status: offline
I need a new canopy for my Midwest Texan!!!!! Where can I get one? I see a guy in Greece has one but Greece, thats on the other side of BFE. Any help guys would be great.
< Message edited by bladerunner1955 -- 12/22/2007 8:34:47 PM >
(in reply to WarbirdAirRacer)
       Post #: 36
RE: MIDWEST AT-6 TEXAN - 2/1/2008 7:39:44 AM
bladerunner1955
Status: offline
Here is a cool clip of my electric Midwest Texan. Swings a 20/12 prop.
http://www.youtube.com/watch?v=RNTAhicEtBU
(in reply to bladerunner1955)
       Post #: 37
RE: MIDWEST AT-6 TEXAN - 2/21/2008 3:02:11 PM
Daniel-EL
Status: offline
I can't find anyone who has actually installed a Saito 170 3-cylinder radial in their Midwest AT-6. Is this possible without making cut-outs in the cowl? My hobby shop dealer is clueless. I am looking to try this combo along with a Keleo header for a scale exhaust exit. Help, anyone? I'd hate to buy the engine, then find I have to butcher the cowl.
< Message edited by Daniel-EL -- 2/21/2008 3:09:41 PM >
I don''t necessarily believe everything I say
...Marshall McLuhan...
       Post #: 38
RE: MIDWEST AT-6 TEXAN - 2/21/2008 5:03:41 PM
Free Bird
Status: offline
What's the inside diameter of the cowl? I have a 170 that I can measure. BTW - that's the same gameplan that I have for the same model!
FB
(in reply to Daniel-EL)
       Post #: 39
RE: MIDWEST AT-6 TEXAN - 2/22/2008 1:06:56 AM
rcmigpilot
Status: offline
quote:
ORIGINAL: Daniel-EL
