RE: Low Aerial Photo Businesses
Tower Hobbies
Logged in as Guest
  Printable Version
Hobbico Electristar Select - RTF
Seller:  Cody85
Details:   $1,200.00   |  10/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Aerial Photography and Video >> RE: Low Aerial Photo Businesses
Page: <<   < prev  1 2 [3]
Login
RE: Low Aerial Photo Businesses - 5/24/2004 9:23:13 PM
aambrose
Status: offline
That's funny! I kinda have the same plan but if/when I get some money in the bank from my venture, I plan to go with something along the lines of what you're getting.
My Draganflyer is supposed to be shipping out tomorrow according to the phone conversation I had with their customer support today. I had to wait 2 weeks for them to build and test it, but hopefully it will be well worth the wait. I have ZERO experience with helicopters so I'm definitely going to take it slow with $1000 worth of "toy". RCToys (the Draganflyer web site) is working on a CCD camera and I have been told they hope to have it available in 1-2 months. I'm not sure if it will work on the Draganflyer IV. I was also told it will probably run about $100 more than their Eyecam CMOS camera which should put it around the $350 price tag.
There you go! Asking me for my secrets! I'm guessing I could take footage from one area, then pack things up and go to another area, and so forth to get enough footage. As for editing software, I have Adobe Premiere version 6.0 but I would like to upgrade so I can burn DVDs. Premiere is a pretty powerful editing package but it has a fairly steep learning curve.
_____________________________
Tony
(in reply to MalachiConstant)
       Post #: 51
RE: Low Aerial Photo Businesses - 5/24/2004 9:36:00 PM
MalachiConstant
Status: offline
Yeah, it is a funny name for their site. I wouldn't consider anything in the $1000 range to be a toy. Helis are just expensive. The cheapest one I have found is the aerohawk, which is cheaply made in hong kong, flies terribly and is a general piece o' crap. And still, it is about $180.
You definitely want to take it slow, although from what I have heard, repairs on the draganflyer are pretty cheap. The only unfortunate thing is that there is no way to practice it on a simulator. Practicing with simulated helis probably wouldn't do you any good.
Be sure and post a review once you get it up and flying.
(in reply to aambrose)
       Post #: 52
RE: Low Aerial Photo Businesses - 5/25/2004 3:33:24 AM
aambrose
Status: offline
I'll be sure to let you know how it is.
Tony
       Post #: 53
RE: Low Aerial Photo Businesses - 5/25/2004 3:17:32 PM
ihaveatxt1wow
Status: offline
quote:
ORIGINAL: aambrose
I downloaded videos from both CMOS and CCD cameras, and the one comes with Draganflyer IV is not bad at all. Yes it is little more clear with CCD, but hey, it is also $100-200 cheaper. Plus, it will take a few crashs before you can comfortably hover your Draganflyer IV 30-40 ft over your head. You do not even want to put a $200 camera on board before that, right?
       Post #: 54
RE: Low Aerial Photo Businesses - 5/25/2004 3:20:18 PM
aambrose
Status: offline
Thanks for the tips! Please keep us updated!
Tony
(in reply to ihaveatxt1wow)
       Post #: 55
RE: Low Aerial Photo Businesses - 5/28/2004 2:53:17 PM
aambrose
Status: offline
Well, it's time for my first review of my DF IV. After waiting over 2 weeks to receive it, it finally came yesterday. I opened everything carefully, read the manual and took my time assembling it. While doing that, I charged the transmitter and li-poly packs for the DF. I realize the transmitter needs 14+ hours to fully charge but the manual suggests charging it while assembling the DF so it will have enough juice to complete the setup.
All went well and the thing assembled nicely. There are a few minor tricky things but overall it went together nicely. From start to finish, I spent just under 2 hours. That's going very slow, reading, taking my time, and in no hurry.
I placed the battery pack on the DF and plugged it in. After that, I put the DF on the floor, turned on the tx then the DF and the little red LED came on just as described. Its flashing rate increased with throttle input - just as stated. I returned the throttle to the lowest position, armed the DF by pressing the arming button, then increased the throttle slowly. It worked! I took it very slow and got used to the controls. It was a little squirrelly so I took it out into our garage for more room. After practicing intermittently for an overall total of about 10 minutes on the DF, I decided to let it rest for a few minutes. I had the thing hovering (briefly) a few times and I was somewhat pleased at my first few minutes, although I knew it was going to take some time to master. My wife came home and I couldnt wait to show her. If you havent noticed already, I'm using "past tense" verbs here! I turned on the tx, then the DF but this time, the red LED didnt glow! I even replaced the battery pack with a fresh pack....Nothing! I even tried charging the tx for a couple more hours but it still didnt work. I attached the Eyecam to the DF and it received power from the battery pack but the DF didnt seem to be getting any power (or lack of signal from the tx). I even charged the tx overnight and tried everything again this morning but it still didnt work.
Needless to say, I'm extremely dissatisfied at this point. I took my time, did everything correctly and carefully, and got to tinker with the thing for less than 10 minutes total flight time! I have $1000 invested in this and it does nothing now! I have a call into Draganfly Innovations but it seems their customer service/tech support is no where to be found! If they tell me to pack it up and ship it back, then I'm just going to get my money back. I refuse to wait another 2+ weeks! I'll buy an RC helicopter if that's the case! Yeah, I'm mad!
Tony
       Post #: 56
RE: Low Aerial Photo Businesses - 5/28/2004 3:23:59 PM
rajul
Status: offline
Is there any website giving info on vibration-proof mounting for cameras on helis ?
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
       Post #: 57
RE: Low Aerial Photo Businesses - 5/28/2004 6:44:04 PM
aambrose
Status: offline
I've been on the phone a few times with the folks at Draganfly Innovations and I have to say that they are very willing and cooperative. They are sending me a new circuit board and some capacitors for the motors. At this point, they are proving to be very helpful. Sure makes me question the durability of the DF IV though since I barely eeked out 10 minutes of stick time before all of this happened.
Tony
(in reply to rajul)
       Post #: 58
RE: Low Aerial Photo Businesses - 5/28/2004 8:55:37 PM
MalachiConstant
Status: offline
Sorry to hear about your problem, and I know it must be frustrating. I have been waiting over two weeks for my heli, and it hasn't even shipped yet.
However, don't put too much stock in a single sample as an estimate of reliability. Maybe they get failures one out of every 1000 units. Or maybe one out of every 2. You can't really tell the overall reliability just from looking at your single unit. And the fact that they have good, responsive customer service is a great plus in their favor. Also, most electronic items fail very early in their lifetime, or very late (the so-called "bathtub" curve), so it is not surprising that it failed after ten minutes. I wonder how much burn-in testing they do?
Anyhow, keep your chin up, and hang in there. Go spend some more time practicing on the simulator, if you have one. If you don't, then you should get one. :-)
       Post #: 59
RE: Low Aerial Photo Businesses - 5/28/2004 9:07:19 PM
aambrose
Status: offline
Yeah, I feel a little better knowing that that are willing to "right" the situation and in a timely fashion. I'm just disappointed because I spent 2+ weeks waiting and anticipating then I spent 2 hours reading the manual and assembling everything so I would be assured that everything was correct. It was very fun while it lasted so I'm really looking forward to having it work again. I hope mine was a fluke because I would think that everyday "normal" flying would be rougher than what I put it through in just a few minutes.
I have no RC simulators but I've also heard that no simulator will help with the DF. I dont know how true that is though.
Tony
       Post #: 60
RE: Low Aerial Photo Businesses - 6/3/2004 11:03:58 PM
Shok
Status: offline
ok well I havent checked back since starting this thread for awhile but im 99% ready to start.
I was able to acquire a Vario Silence electric heli here on RC Universe for around $400 ready to fly!
I saved about $1000!!
I also got a custom made cam mount from helicamsolutions that incorporates both tilt and pan for about $350.
Then I bought the new digilive transmitter system from Blackwidow for $285.
Im basically all set. Just need to do some finish up on the chopper here and there and re-engineer the camera shutter actuation and I am ready to roll.
This helicopter should be able to lift about 5 pounds and my cam setup is looking to be right under 4 pounds.
I have talked to some real estate agents that are excited about this and want me to get with them when i am ready to go.
Ronnie
Jetmach, Flyeagle, JetCat Sales
www.laser-design-services.com
       Post #: 61
RE: Low Aerial Photo Businesses - 6/3/2004 11:08:08 PM
MalachiConstant
Status: offline
Awesome!
I haven't heard anything about that particular heli. Can you post a link to specs, or tell us what they are? That sounds like an awesome deal.
I'm also curious why you didn't go with the helicamsolutions downlink. I think it was about the same price.
I'd also love to hear how your discussions go with the real-estate agents. What kinds of things did they ask about? What price are they looking for. That kind of thing.
Good luck to you, and be sure to let us know how it goes.
(in reply to Shok)
       Post #: 62
RE: Low Aerial Photo Businesses - 6/4/2004 4:56:04 PM
aambrose
Status: offline
Sounds very cool Ronnie! I can't wait to hear your updates!
RCToys sent me a new circuit board and some capacitors for my Draganflyer IV. They shipped it Airborne Express and it was on my doorstep in 2 business days considering Monday was a holiday. They even threw in a few extra frame parts at no charge! They definitely seem to stand behind their products and want to keep the customer satisfied.
I soldered the new capacitor on the motor but the DF still didnt work. I replaced the circuit board and it worked. I've had it airborne a few times and I'm able to hover it but it's going to take some practice before I can fly it around comfortably. My thumbs are still used to flying RC planes and I'm learning to use more left stick, but I find it very challenging and fun. Someday I'd like to move up to an RC helicopter and something along the lines of what Ronnie is doing.
As for the Draganflyer IV...it's a lot of fun but it defintely takes practice. The size and shape makes it somewhat difficult to keep it oriented forward but that's part of the fun right? My practice sessions usually last about 10 minutes or so and that includes walking over to pick up the DF and position it back on the "pad". I'm having fun just learning how to fly it so I can imagine it will be a blast once I'm more proficient!
Tony
