jrf
CA, USA Status: offline
quote:
ORIGINAL: Idahoplane Now for the $60,000 question. Now that I am coming to a completion on this plane, does anyone have a suggestion on how to "easily" interchange the float cables so one can fly with either the floats or wheels? It appears the float cables are permanently attached and you have to cut the cable every time you switch. My first thought's are the brass sleeves will come off easily. Let me know, please. You need to crimp and glue the brass sleeves in place, otherwise they will probably "come off easily" (or at least slip) when you don't want them to. Instead of using the sleeves, use EZ connectors to hold the water rudder cables to the servo arm. Solder the very tip of the cable so that it doesn't unravel and just slip it through the EZ connector and tighten it down. If you don't distort the cables too badly when you tighten the connectors, they will still slip in and out through the guide tubes. Jim
