fourboltmain
Joined: 4/9/2004 From: Glendale, AZ, USA Status: offline
Those things like it fat on the bottom. It is an excellent race motor, but a pretty poor bashing motor. The reason is because it will heat up if sutained wide open throttle is used. You tune the bottom rich to cool the cylinder and tune the high speed for your throttle response and speed, and it tends to be a little lean to accomplish this. Since in a racing situation you are blipping the throttle a lot, the cool fuel when the RPMs drop keep the cylinder cool. A lot of RB guys tune like this too, but the Sirios have a three mixture adjustment carb (Low, Med and High) and the RBs have a two mixture adjustment carb(Low, High). The tune on the two, however, is very similar. If you tune it like an O.S., you'll give up and be very frustrated with the engine. If you tune it like it wants to be tuned, it is scary fast. P.S. don't tell anyone about this, as long as people keep thinking they suck I can buy them cheap
