Wildcat Fuels
Dear ShempHoward, By the way cool name! There is a distinct difference in low viscosity oil and high viscosity oil, and yes protection is the key. The higher viscosity oil protects better. I also think Mr. Wizard was a really cool guy, could be why I ended up being an Aerospace Engineer and taught at a major University....I also like McGyver...way cool.....and duct tape! Den, you had to richen up because of the oil viscosity, being "thicker" the fuel needs more room "richening" to get by the needle. Less Smoke/More Power/Superior Mid-Range - For years heli pilots associated good lubrication with large amounts of smoke, this is simply not correct. Oils used in R/C fuels can be of different viscosities (different thicknesses or weights) some fuels use large volumes of less viscous (thinner) oil with the idea that since the oil is thinner the engine will be able to accelerate quicker and the greater volume will make up for the reduced protection that the less viscous oil provides. In a few respects this is true, but the penalties outweigh the benefits. By using the less viscous oil a much greater volume is required for lubrication, this in turn reduces the amount of burnable fuel available (the oil does not burn) and thereby reduces power. Usually the result is the pilot over leaning the engine trying to extract the power. The larger volume of oil also produces excessive smoke (carbon) during combustion. WILDCAT uses a more viscous oil at 18% volume. This oil better protects the piston with a stronger shear strength and load carrying capacity lubricant. It also provides for a better seal between the piston and the sleeve, this in turn allows for higher compression due to the reduced blow-by ie.. more power. Because we use a more viscous grade of oil we can use the 18% volume, this allows more methanol and nitromethane (fuel) for the combustion process ie... more power. By using a higher viscosity oil we can use the recommended amount that meets and exceeds most warranty requirements including the popular OS heli engines. Using a more viscous grade of oil also provides for our next benefit, better heat removal. In straight forward engineering terms the greater the viscosity the higher the heat capacitance. In english, the thicker the substance the more heat it will absorb in a given amount of time. The higher viscosity oil can simply carry away more heat from the engine. Once again, this provides for a cooler running engine that will make more power and transition better. Hope this helps your discussion. Jerry Conley
< Message edited by Wildcat Fuels -- Jul 2 2002 1:09PM >
