RE: Raco JackRabbit Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: Raco JackRabbit Thread
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Raco JackRabbit Thread - 7/6/2004 2:24:29 AM
oldskool
Status: offline
Yeah, I would say so. Wish more people would post, I know there are more Jacrabbit owners out there.
_____________________________
Drive Faster, Crash Harder!
(in reply to pb_paulie_b)
       Post #: 51
RE: Raco JackRabbit Thread - 7/7/2004 12:36:34 AM
pb_paulie_b
Status: offline
i'm a lil exicited to see your blue one again. let me know if the paint holds up, i'm temped to paint mine.
owner worlds most powerful jacrabbit :)
(in reply to oldskool)
       Post #: 52
RE: Raco JackRabbit Thread - 7/7/2004 12:41:08 AM
oldskool
Status: offline
It has held up so far and I have abused that body a lot so far. I just used a lot of primer and a poliurithane clear coat over the paint job. I works a bit better then basic clear coat.
< Message edited by oldskool -- 7/6/2004 7:53:58 PM >
       Post #: 53
RE: Raco JackRabbit Thread - 7/7/2004 1:50:19 AM
merrittd
Status: offline
have any of u all tryed drifting w/ ur jackrabbit? im gonna try after i get some stuff 4 it 2morow
       Post #: 54
RE: Raco JackRabbit Thread - 7/7/2004 1:16:11 PM
oldskool
Status: offline
My rabbit drifts all the time. It is very easy to do in dirt. On cement the buggy has a tendency to over streer. But if you practice it enough, you can do it really well. Don't use a good pair of tires otherwise you won't have good ones by the time you are done.
(in reply to merrittd)
       Post #: 55
RE: Raco JackRabbit Thread - 7/7/2004 8:17:12 PM
pb_paulie_b
Status: offline
i drive mine at a baseball field sometimes and stand in the middle near the pitchers mound. i drive my jacrabbit around me in circles with it drifting the entire time! it's real easy to drift with the locked rear (full time posi-traction). friends think it's sooo easy to drive till i let them loose in a big field. i've never seen the dude who takes care of that baseball field, he prolly hates me and wonders what makes all those marks
       Post #: 56
RE: Raco JackRabbit Thread - 7/8/2004 8:53:13 PM
oldskool
Status: offline
I did the same thing before. Drifting is really fun, like you said it is very easy to drift around things. You should try to set up a course with cones in the dirt and drift around each one. That helps build up your skills when you are drifting both left and right. I use to do this with real cars in the winter time around trees, and it has helped me quite a bit.
       Post #: 57
RE: Raco JackRabbit Thread - 7/9/2004 1:26:05 AM
pb_paulie_b
Status: offline
does your rabbit "turn" better one way than the other? no matter how many times i set her up i just can't find that happy medium?
       Post #: 58
RE: Raco JackRabbit Thread - 7/9/2004 1:40:55 AM
merrittd
Status: offline
i was talking about drifting w/ pvc tires on pavement, w/ the slicks i have on mine i can do it in the dirt real easy but never on the cement
       Post #: 59
RE: Raco JackRabbit Thread - 7/9/2004 1:58:21 AM
oldskool
Status: offline
I can drift with the original rubber tires good in dirt and I am pretty good at on pavement to. It is just a bit hard to get the back end around on cement.
       Post #: 60
RE: Raco JackRabbit Thread - 7/9/2004 1:58:33 AM
pb_paulie_b
Status: offline
i can do it with the knobbies i have on there now but i try not to too $. i havn't tried with my rubber slicks because there is no where "safe" for me to drive on cement. these are the ones i use. they are pointless to use anywhere else unless i'm just try'in to do doughnuts.
Click to see fullsize image.
Click for fullsize
       Post #: 61
RE: Raco JackRabbit Thread - 7/9/2004 2:05:07 AM
oldskool
Status: offline
They are rubber I take it? I have a set of foams that are useless to me also. I use them for the same reason.
       Post #: 62
RE: Raco JackRabbit Thread - 7/9/2004 2:24:55 AM
pb_paulie_b
Status: offline
they are extremely worn stock tires...PB
       Post #: 63
RE: Raco JackRabbit Thread - 7/9/2004 2:32:16 AM
oldskool
Status: offline
Extremly!!! My tires are not far from those. can't wait to get this other Jac Rabbit I will be having lots of fun then. Plan on racing my freind to see if he can handle the Raco Jac Rabbit. As long as he dosen't hurt it he will be fine.
       Post #: 64
RE: Raco JackRabbit Thread - 7/9/2004 5:58:06 AM
decalman
Status: offline
3 and a 1/4,
show em what's up!!!!!
       Post #: 65
RE: Raco JackRabbit Thread - 7/9/2004 5:59:26 AM
merrittd
Status: offline
how many of u all would buy a new body for ur jackrabbit, im thinkin bout havin sum made
       Post #: 66
RE: Raco JackRabbit Thread - 7/9/2004 9:56:12 AM
oldskool
Status: offline
I need a body for one of mine's. I wouldn't buy one brand new though, they are way to expensive. I would try to buy a used one off of someone else. The bodies seem to be easy to make with that design. But I think it would be to much of a pain to do it. I would just find something used.
       Post #: 67
RE: Raco JackRabbit Thread - 7/9/2004 9:50:52 PM
pb_paulie_b
