60 sized helis
Tower Hobbies
Logged in as Guest
  Printable Version
Walkera 53#8!! 5G6-1. Nine Eagles Kestrel 500's - RTF
Seller:  travis@rchelizone.com
Details:   $165.00   |  11/9/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> 60 sized helis
Page: [1]
Login
60 sized helis - 5/4/2004 4:01:26 AM
Shok
Status: online
Can someone list some 50-60 sized electric helis that can lift about 3lbs and about how much they run?
I'm clueless on electrics.
thanks
_____________________________
Ronnie
Jetmach, Flyeagle, JetCat Sales
www.laser-design-services.com
       Post #: 1
RE: 60 sized helis - 5/4/2004 5:59:01 AM
Hoverup
Status: offline
http://www.fxaeromodels.com/joker.htm
(in reply to Shok)
       Post #: 2
RE: 60 sized helis - 5/4/2004 2:25:14 PM
Shok
Status: online
any others?
Is the Voyager E, a .50 sized heli?
Ronnie
(in reply to Hoverup)
       Post #: 3
RE: 60 sized helis - 5/4/2004 4:18:43 PM
heli143
Status: offline
try here:
http://www.v-eastonline.com/grapstarElec.html
Sandy is a great guy to deal with and sells quality products from what I have heard.
Good Luck.
(in reply to Shok)
       Post #: 4
RE: 60 sized helis - 5/4/2004 4:25:26 PM
Shok
Status: online
how much does that one run? I don't see a price
Ronnie
(in reply to heli143)
       Post #: 5
RE: 60 sized helis - 5/5/2004 9:19:30 PM
heli143
Status: offline
Shok,
which one are you asking about. I can't see your eyes to see who you are looinig at
(in reply to Shok)
       Post #: 6
RE: 60 sized helis - 5/5/2004 9:37:28 PM
Shok
Status: online
well whatever one was on that page lol
what kinda of prices am I looking at for a 60 sized electric
Ronnie
       Post #: 7
RE: 60 sized helis - 5/6/2004 5:12:55 AM
FHHuber
Status: offline
Just about any glow heli can be E-converted. Just stick in the correct electric motor and ESC... strap on the batteries and fly it.
An example is a local guy has E-powered a Centrury Hawk which now outperforms my glow powered one. He did the E-conversion but did not do any other upgrades... so its a good comparison.
The cost of the E-power system is usually higher than the glow engine. However, over time the savings from not having fuel would make the e-power model cheaper. (if you don't break the E-drive stuff or burn up the batteries...)
You can direct drive the heli from the e-motor. No clutch needed. The e-motor isgenerally lighter than equivilent gow power engine. The batteries tend to make up for the weight savings though... and may have the final package heavier to get the same flying time with similar performance...
There is an advantage to the e-power that is hard to argue with... the motor just won't die on you with no warning. You only do "autorotations" if you WANT to do them. When the batteries are lo on power... the performance degrades... telling you to land for recharge (or battery swap)
(in reply to Shok)
       Post #: 8
RE: 60 sized helis - 5/6/2004 3:13:09 PM
Shok
Status: online
what do you guys think about the V-East Starlet 50 Elektro?
Ronnie
(in reply to FHHuber)
       Post #: 9
RE: 60 sized helis - 5/8/2004 12:32:28 PM
Shok
Status: online
Or where can I find a Voyager 50E?
Ronnie
(in reply to Shok)
       Post #: 10
RE: 60 sized helis - 5/8/2004 3:59:01 PM
gliderpilot69
Status: offline
If you want a nice big electric heli for lifting there is a Joker Maxi. It has a 1.8 meter rotor disc. The main blades are 800 mm. The tail rotor is up turned like on a UH-1. Fitz has them a FX Aeromodels. They aren't cheap but helis in general aren't cheap. The Joker Maxi should lift about 2 kg wich is around 4 and a half pounds. It takes 32 cell nimh or 10s and depenging on desired run time 3p or 4p on the lipos. The lipos are alot more expensive but the weight savings means more payload. I hope to get my Joker flying when I return. Militairy duty calls again.
Cheers,
Shannon
(in reply to Shok)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU4
