Multiplex microJET Balancing
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> Multiplex microJET Balancing
Page: [1]
Login
Multiplex microJET Balancing - 5/5/2004 1:00:56 AM
millet_flyer
Status: offline
As you see in my picture it is complete. I am unsure about the balancing though. The instructions say balance it level. OK, but the profile of this thing is round. So do I balance it with the wing level or with an AOA built in??? This jet is basically stock except for an 8 cell NiMH. I measured 300g of thrust and it weighs 472g. Any help is appreciated. Thanks.
_____________________________
I fly... MPX Micro-JET, GAD F-15, 18, 5 Su-27, B-52, F-5
Peter
       Post #: 1
RE: Multiplex microJET Balancing - 5/9/2004 11:26:00 AM
twang
Status: offline
Gidday,
If you are using an 8 cell KAN 1050mAh pack in a standard Microjet you will find it a bit nose heavy. I am assuming you are using the 400 motor and gunther prop as supplied. The symptoms will be a tendency to drop the nose when power reduces and not hav enough elevator to recover. As far as balancing it level I don't think it is critical, just make it look right and balance just on the front edge of the bumps. Throws are as published with the addition of 20% expo. I have given up hand launching and use a foot pedal bungee.
Hope this helps
(in reply to millet_flyer)
       Post #: 2
RE: Multiplex microJET Balancing - 5/10/2004 7:25:06 AM
millet_flyer
Status: offline
Thanks for your input. The first flight will be with the 7-cell pack. Expo setups are already set for 10, 20, 35%. My throws are set to their wishes, but keep in mind this is the maiden flight. They do mention that you can increase the throws by 2-3mm. My first few flights will only be slow, just to see how slow it can fly and when it stalls. With that I hope to set up my landing program. This plane seems to look right with about 6 to 7 deg of attack. What do you think...
Peter
(in reply to twang)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU4
