CA 27% Extra 300L, what hinges ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> CA 27% Extra 300L, what hinges ?
Page: [1]
Login
CA 27% Extra 300L, what hinges ? - 5/6/2004 3:43 AM
fdo300
Score: 100
Last Login: 5/23/2013
Status: offline
Hi
I'm building a CAmodel 27% Extra 300L and I have to take a decision about what hinges to use.
aileron and elevator ar top hinged, I like the radio south CA hinges but I haven't use them in large model before now.
So.... what do you think is better, CA, dubro, robart ???
Regards
Fernando Viollier
Hide Signatures
       Post #: 1
RE: CA 27% Extra 300L, what hinges ? - 5/6/2004 3:48 AM
caravanflier
Score: 100
Last Login: 12/27/2007
Status: offline
i prefer the robarts by far
Hide Signatures
(in reply to fdo300)
       Post #: 2
RE: CA 27% Extra 300L, what hinges ? - 5/6/2004 4:02 AM
compute42
Score: 100
Last Login: 12/19/2012
Status: offline
There's a long thread about the CA 27% somewhere in here... do a search for Colombo
Top hinging with robarts looks to be very tough.
Hide Signatures
       Post #: 3
RE: CA 27% Extra 300L, what hinges ? - 5/6/2004 4:37 AM
jongurley
Score: 100
Last Login: 4/9/2013
Status: offline
I used robarts,,, but my CA is center hinged ,,,,,
Hide Signatures
(in reply to compute42)
       Post #: 4
RE: CA 27% Extra 300L, what hinges ? - 5/6/2004 8:14 AM
Ryans Rebel
Score: 100
Status: offline
Don't use CA hinges on the CA. The stabs are foam core and the CA will eat the foam. I used robarts but mine was center hinged. It may be worth the time to make your center hinged as well.
Ryan
Hide Signatures
(in reply to jongurley)
       Post #: 5
RE: CA 27% Extra 300L, what hinges ? - 5/6/2004 5:19 PM
jongurley
Score: 100
Status: offline
Yeh Ryan that is what I was thinking, if there is anyway to take a extra afternoon go on and center hinge them..... It will pay off in the long run and the robarts are so easy to epoxy in...
Hide Signatures
(in reply to Ryans Rebel)
       Post #: 6
RE: CA 27% Extra 300L, what hinges ? - 5/6/2004 10:08 PM
promag
Score: 100
Last Login: 2/11/2013
Status: offline
Don´t use CA hinges planes this size. In my 27% Edge I use Robart pin hinges 3/16" (ROBQ 310) and works very well. Glue used Pacer hinge glue.
Hide Signatures
       Post #: 7
RE: CA 27% Extra 300L, what hinges ? - 5/8/2004 7:07 AM
Abraxxas
Score: 100
Last Login: 8/22/2011
Status: offline
My WH Edge came pre-drilled for the supplied Robart hinge points, this was my first experience with them... I installed them using Elmers Probond and I can honestly say I dont think I'll ever use anything else. They are easy to put in, I really like the barbed shaft for security and they look cool too The Probond glue is some amazing stuff as well, just the perfect amount of foaming to fill the voids, and you have tons of working time to get everything perfect.
Good Luck
Brian
_____________________________
"Hey, everybody land for a minute and shut your planes off, I have to call in sick..."
It must be 8am at the field agai
Hide Signatures
(in reply to promag)
       Post #: 8
RE: CA 27% Extra 300L, what hinges ? - 5/8/2004 3:15 PM
davidmor
Score: 100
Last Login: 9/12/2006
Status: offline
I just finished hinging my Midwest 80" Extra with Robart hinge points and I have to say, I don't think I will use anything else in the future. I used Probond glue and followed the video tutorial I found on this site. I have used CA, tape, monokote, and flat pinned hinges on many planes in the past, and the hinge points were by far the easiest method I have ever used. The line up perfectly if done correctly, and they seem to be very strong. Using polyurethane glue like Probond or Gorilla glue gives you a plenty of time to get everything together and lined up, and the foaming fills all of the voids in the wood and around the barbs. I was very impressed with them and they look great too!
Hide Signatures
       Post #: 9
RE: CA 27% Extra 300L, what hinges ? - 5/9/2004 9:20 AM
3dbatixkid
Score: 100
Last Login: 11/8/2004
Status: offline
Hope this helps. These are Klett hinges (arent being made anymore from what i hear). Then hinge slots are cut down into the meat of the wing, and are then glued in with epoxy.
Click to see fullsize image.
Click for fullsize
Click for fullsize
www.3dbatix.com
Hide Signatures
(in reply to davidmor)
       Post #: 10
RE: CA 27% Extra 300L, what hinges ? - 5/9/2004 5:42 PM
TT2
Score: 105
Last Login: 12/2/2011
Status: offline
I built the CA Extra 31% and followed the instructions to the letter during sheeting / hinging at the hingelines. I regret it now. They turned out very nicely but it took FOREVER and was quite difficult to build and keep everything lined up perfectly.
I'm most likely going to build another CA Extra this winter but I'm going to do things differently next time around to speed up the build significantly.
Instead of beveling the foam and capping it at the hingeline (per instructions), plan on using 1/2" thick hard balsa (one for the LE, one for the TE) at the hingelines and Robart hinge points. Increase or decrease the thickness of the hard balsa depending on how much bevel you want. Mark the control surface and allow a gap for the hard balsa. Cut the pieces with a bandsaw using the bottom foam shuck to keep the cuts perpendicular to the wing. Sand the surfaces perfectly flat with a bar sander / 80 grit.
Cut the two hard balsa hingeline pieces to length and tape them together near the ends. Mark the hinge point positions. In a drill press, drill holes for the hinge points through both pieces at once. Remove the tape. Countersink the holes for the hinge points at the face of each piece. Bevel the hinge line pieces with a sanding bar or band saw. Use short pieces of appropriate-sized brass tubing in the hinge holes going into both pieces of hard balsa to keep the holes lined up. These pieces should be just short enough to not protude past the gluing surface of the hingeline pieces. Glue the hingeline pieces into place with Pica Gluit or other sandable aliphatic glue. If you use polyurethane glue here, some might seep into the holes you've created and could make the brass tubing 'locator pins' difficult to remove. I have found that the Gluit sands easier than the poly glue also. Tape the hingeline pieces to the flying surface / control surface carefully centering the hingeline vertically. Alternately you could use some hardpoints in the flying surface / control surface to increase the pull out strength but I feel this is overkill.
Once everything has cured, remove the brass tubing 'locator pins' and sand the hingeline pieces flush with the flying surface / control surface. Bore holes into the foam with a piece of sharpened brass tubing deep enough to allow installation of the hinge points. Cover the hingelines then create holes in the covering at the hinge holes with a soldering iron. Now you're 100% ready to install the hingepoints with polyurethane glue.
Though this method may sound difficult it is QUICK and very accurate. I'm sure that building the hingelines per instructions and using 'flat' style hinges (and the covering problems they create) takes at least three times longer if not more.
-Tom
< Message edited by TT2 -- 5/9/2004 9:55:39 AM >
Hide Signatures
(in reply to 3dbatixkid)
       Post #: 11
RE: CA 27% Extra 300L, what hinges ? - 5/9/2004 10:30 PM
Geistware
Score: 100
Last Login: 5/2/2008
Status: offline
Use the robert pin hinges
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
Hide Signatures
(in reply to TT2)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
