Broken screw! Need Help
Tower Hobbies
Logged in as Guest
  Printable Version
Team Losi 8ight-T - Kit
Seller:  fcbuilder
Details:   $1.50   |  11/18/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> Broken screw! Need Help
Page: [1]
Login
Broken screw! Need Help - 5/7/2004 6:19:21 PM
Alden
Status: offline
The grub screw on the collar for my lower suspension arms head has been messed up, the hex driver just keeps spinning(no grip, the hole is more round than hexagonical anymore) I need to get the grub screw out so i can replace it, i would rather not replace the whole collar as they are hard to get here, please give advice on how to remove it.
Thanks, please help.
< Message edited by Alden -- 5/7/2004 6:20:30 PM >
       Post #: 1
RE: Broken screw! Need Help - 5/7/2004 6:47:54 PM
samcim
Status: offline
Hi,
if you got a dremmel or a small hacksaw u can cut a line in the top ov it and screw it out with a flat head screw driver, also ive heard some ppl glueing a screw driver to it and screwing it out that way but i dont think that would work on a tight screw.
good luck
< Message edited by samcim -- 5/7/2004 1:49:21 PM >
(in reply to Alden)
       Post #: 2
RE: Broken screw! Need Help - 5/7/2004 7:11:29 PM
Alden
Status: offline
The screw is sunk into the collar i cant cut at it
(in reply to samcim)
       Post #: 3
RE: Broken screw! Need Help - 5/7/2004 7:21:01 PM
samcim
Status: offline
what about using a small drill bit to make a few holes in a line then use a flat head screw driver to take it out ????????????????????????????????
< Message edited by samcim -- 5/7/2004 2:21:24 PM >
(in reply to Alden)
       Post #: 4
RE: Broken screw! Need Help - 5/8/2004 9:12:57 AM
ask52
Status: offline
you could try this: take a small hex key (use a old junky one so you don't wreak a good one), put a dab of jb weild on the tip then place it in the striped screw. once it drys turn it out! I'm not sure if it will work but its worth a try.
       Post #: 5
RE: Broken screw! Need Help - 5/8/2004 9:18:18 AM
Da Smak
Status: offline
That is the easiest way and it does work.
(in reply to ask52)
       Post #: 6
RE: Broken screw! Need Help - 5/8/2004 3:48:07 PM
Alden
Status: offline
thx for the replies but i managed to get it out without having to get to dirty, I used someones 1/16 size hudy driver instead of the 1.5 mm hex key and it came straight out :P.
(in reply to Da Smak)
       Post #: 7
RE: Broken screw! Need Help - 5/10/2004 7:50:45 PM
mattyk6
Status: offline
Ain't it amazing what the right tool can accomplish?
This coming from a person who is still using a 1.5 mm key.
(in reply to Alden)
       Post #: 8
RE: Broken screw! Need Help - 5/11/2004 11:24:38 AM
RCaeroguy
Status: offline
I've used a small straight blade screwdriveer and jam it into the rounded hex in the screw. Works great.
_____________________________
Where are all the good men dead: in the heart or in the head?
(in reply to mattyk6)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.719RCU4
