RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate Appearance
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
F4U Corsair ARF - 60
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate Appearance
    Page: <<   < prev  1 2 [3] 4 5 6   next >   >>
    Login
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate... - 10/27/2005 11:45:44 AM
    Rocketman612
    Status: offline
    LDM,
    http://cajunrc.com/Model_Graphics/cajunrcspecial/index.htm
    Denny set me up with excellent graphics. He can resize for the H9 Corsair. Give him a call.
    Pete
    _____________________________
    "Remember, all im offering is the truth, nothing more..."
    Morpheus
    (in reply to LDM)
           Post #: 51
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate... - 10/27/2005 2:22:44 PM
    CorsairJock
    Status: online
    quote:
    ORIGINAL: LDM
    6)next need to remove decals , looking to do tri color scheme , need advice on where to buy new decals for the Tri color version please
    If you are looking for the red-outlined national markings (1943 style), then try to find one of the old Top Flite 'red box' Corsair sets. The size is correct for Hanger 9 Corsairs, they look great, and that is what I have on my electric powered H-9 Corsair.
    OR, as Rocketman suggested, have some made up by a custom grafix maker.
    Can't awit to see those pics.
    Click to see fullsize image.
    Click for fullsize
    Avatar: Electric Powered, Highly Modified Hangar 9 Corsair
    (in reply to LDM)
           Post #: 52
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate... - 10/28/2005 7:08:52 PM
    nemesis4u
    Status: online
    EVT ,
    Would you post some more pics of your Highly Modified H9 Corsair for us to enjoy? any more input in terms of how you modified the wing for flaps etc would be appreciated..Truly spectacular model..Like the Sliding Canopy..
    Where did you hide your tail group servos?
    R/C WARBIRDS / RC TANKS ENTHUSIAST
    VQ WARBIRDS, KMP, & RCV
    (in reply to LDM)
           Post #: 53
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate... - 10/29/2005 10:12:21 PM
    evt
    Status: offline
    Thanks, nemesis. This plane was stolen from my garage a year ago and I just got tis plane back thanks to Corsairjock who noticed it was posted in an online auction. The police picked it up along with alot of my other RC gear. It has alot of hangar rash and needs some repair work to get it up to par now.
    The servos are mounted under the cockpit and connect to the elevator and rudder inside the fuse. To make the flaps I carefully cut 2 1/2" of the rear wing off and cut this into 3 pieces to make the flaps. I removed another 1/4" from the wing and glued balsa anchors for the hinges flush to the cut and then glued 1/4" end cap to the rear of the wing and sanded to shape. I cut 1/2" of the rib and sheeting out of the top of the flap pieces and glued in 1/2" balsa (curved shaped for the center flap) to the bottom flap sheeting and rib. I sanded 1/8" off each side of these flaps and glued identically shaped (to the flap profile I wanted) 1/8"ply end caps with holes drilled for the wire rods to connect the flaps on the ends of the flaps. Then rounded the top leading edge of the flaps even with the shaped ply end caps and trial fit them to the wing. Lots of sanding and trial fits with hinges and connecting rods but it works just like the TF flap design. One servo in center wing operates bell-cranks angled to the bottom of the wing in front of inner flaps. I also routed a 1/32 recess in the top of the rear wing end cap so I could glue a 1/32 ply trailing edge to cover the flap hinge line. This cap hung over the flaps about 3/16.
    Not sure if you get all that its hard to explain without pics. Canopy was made with a mold and the sliding mechanism is just like dionysusbacchus' royal corsair mods. Check it out for more great corsair ideas! Ed
    http://www.rcuniverse.com/forum/m_627400/anchors_627400/mpage_1/key_royal%252Ccorsair/anchor/tm.htm#627400
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    (in reply to nemesis4u)
           Post #: 54
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate... - 10/30/2005 6:31:51 AM
    DVM100
    From: Canberra , Australian Capital Territory, AUSTRALIA
    Status: offline
    Hi Jim,
    I have a H9 Corsair which I have flown a few times, and it flies beautifully I must say. Unfrotnuately my last flight was a mini-disaster. On approach I lost elevsator andshe did a nose dive (albeit at slow speed), but it was enough to separate the firewall and wing. I am in the process of putting herback together and try as I might, getting replacement H9 bits was near impossible. I then ordered some TopFlite stuff from Tower Hobbies to replace the cowl and dummy motor which took most of the impact.
    I have just finished reading your threads on this and the TF Corsair (all 17 pages!!) and I wanted to express my gratitude and admiration for the work you have done to help out others who are trying their best. I have only been in RC for 10 months and I now have my hangar full of warbirds which fly like a dream. My Spitfire is my pride and joy, but the Corsair is just beautiful to watch and listen to in the air. I am currently finishing off a Mosquito to round out my hangar.
    just wanted to say thanks!
    Dave
    (in reply to CorsairJock)
           Post #: 55
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate... - 2/20/2006 5:50:06 AM
    nemesis4u
    Status: online
    CAN ANYONE PLEASE post pictures of your ZOLLNER CORSAIR COCKPIT INTERIOR?? I am trying to see where to install all the levers and "pin" heads to resemble appropriate levers and buttons... PLease show me your Cockpit.. I especially need to see the left side panel..THanks
    BTW this is one heck of a GREAT KIT>... I have enjoyed putting it together..Just made the oxygen hose...will post pics tomorrow..
    Tomas
           Post #: 56
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate... - 2/22/2006 6:43:48 PM
    dionysusbacchus
    Status: offline
    Hope these help! I made the small red scissors like handle on the aft section of the left panel out of very fine solder, some of it is in the kit. Also make the oxygen bottle tube out of the solder. For the tail wheel lock and other lever, can't remember what it was, just use the T pins. Color your seat belts with Model Master Acrylic paint, gray on the bottom and flat green on the shoulder straps.
    Have fun!
    Dion
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
           Post #: 57
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate... - 2/22/2006 10:14:30 PM
    rt3232
    Status: offline
    Dion
    Did you ever get the 1/6 pylons finished?? If please PM me with infoI wiil respond as I still have time befor our season starts mid may
    Thanks Bob T
    (in reply to dionysusbacchus)
           Post #: 58
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate ... - 3/21/2007 2:38:20 AM
    Bumstead
    Status: offline
    Corsairjock or anyone with a H-9 Corsair...
    Please help. I am rebuilding my Corsair after an eventful tip-stall
    It was destroyed from F-1 forward and need dimensions
    from F-1 to the firewall (new)
    I was told 89mm on the right and 99mm on the left
    but no downthrust figures.
    Any help???
    trombetj@insightbb.com
           Post #: 59
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate ... - 3/28/2007 8:19:07 PM
    juice90
    Status: offline
    hi all. I have a top flight corsair and have been haveing trouble building the wing. I am thinking about ordering a wing kit for the hanger 9 corsair, as the dementions appear to be quite similar.
    Could somebody be kind enough to take some mesurments of the hanger 9 corsair wing and post them for me, so I can see how close the fit might be, before I decide to order a wing kit.
    wing thickness at the fuse, chord at the fuse and width of the fuse would be helpfull and greatly appreciated. I am pretty sure with a small amount of modification, the hanger 9 wing will fit without too much fuss.
    Great ookin planes guys. Thanks
    (in reply to Bumstead)
           Post #: 60
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate ... - 3/28/2007 10:49:07 PM
    CorsairJock
    Status: online
    The 2 Corsair dimensions are close enough that a wing COULD be adapted to the other make. Both have leading edge to trailing edge dimension of about 13" where the wings meet the fuselage. The H9 wing has an extended 'flat' area: the wing is straight where it extends from the fuselage, then it 'bends' down. I have modified my electric one by shortening the center section, thereby eliminating the flat portion where it extends from the fuselage.
    The H9 fuselage has a little bit excessive amount of right thrust. This is great for people not familiar with warbird flying and/ or are rudder challenged. But if you are comfortable with the rudder, and know when to use it (whenever airspeed is low and engine power is high), then some/ most, or even all of the right thrust could be eliminated. I like to leave in just a little: say 1 degree.
    (in reply to juice90)
           Post #: 61
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate ... - 3/28/2007 11:57:45 PM
    juice90
    Status: offline
    Thanks corsairjock. I kinda figured it might be fairly close. The fuse is only in primer anyways so any modifications to it should be simple enough. So, I guess in a few weeks, after i get a few other ones finished up, i'll order a wing kit and give it a go.
           Post #: 62
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate ... - 6/30/2007 10:53:55 PM
    Nitrodan73
    Status: offline
    Corsairjock,
    Just wanted to show you what we have done so far on my H9 Corsair. Tburley is the man I need to thank for helping me and teaching me how to do glass and paint a plane. He has been more than generous helping me out, giving me his time, and using his materials. Check it out!
    Click for fullsize
    Click for fullsize
    < Message edited by Nitrodan73 -- 6/30/2007 10:55:43 PM >
           Post #: 63
    RE: Hanger-9 Corsair ARF Mods for more Scale/ Accurate... - 7/13/2007 7:56:19 AM
