CorsairJock
MI, USA Status: online
quote:
ORIGINAL: Avaiojet Da Rock, About the larger wingspan? I was refering to what Corsair Jock said. He said: "Read the earlier posts. I've shortened the span on 2 of them now, and it's not that difficult. I believe others are doing the same. I don't have time to re-post things ." So I had a question about the span? It's still not answered......................Charles I have a set of very accurate 1/8 scale F4U-1D drawings (from the old D&B Corsair kit), AND Royal Corsair drawings. A long time ago, I compared my H-9 Corsair fuselage to those drawings, and determined that the fuselage was for all practical puposes: 1/8 scale. The only major deviation was in the cowl, both in length and in diameter. Most Corsair kits and ARFs 'cheat' a little on the cowling length: having it longer makes it easier to balance and fly (longer moment). SO, if it is a 1/8 scale fuselage, then the wingspan should be 61.5" (full scale is 41'). Since the H-9 wing is 65": it is slighter longer than scale. BUT, it is really not very noticeable. What IS noticeable, as I stated earlier, is the way that center section juts out of the fuselage. If that part is corrected, as descibed earlier, it will also reduce the span slightly. Reducing the span by a couple of inches won't affect the way these fly: they are light enough that it really doesn't matter. As far as making a choice between the Top Flite kit and the H-9 Corsair: be aware that the Top Flite kit has some VERY noticeable scale inaccuracies, especially in the fin/ rudder and the wing-tips. H-9 did a VERY good job of getting those areas reasonable accurate. The Top Flite kit CAN be corrected, if you know what to look for. I'll be leaving for Kankakee, IL tommorow on a 3 night camping trip. On Sat & Sun, I'll be in the Chicago area to participate in 2 warbird events. SO, if I don't get to your questions soon: you'll know why. http://www.rcuniverse.com/forum/m_7853159/tm.htm
< Message edited by CorsairJock -- 8/21/2008 1:45:36 PM >
_____________________________
Avatar: Electric Powered, Highly Modified Hangar 9 Corsair
