saramos
CA, USA Status: offline
Keith, There are small nav lights near the wing tips on full wings, and lights at the front tips on the clipped wings. I have not seen any photos or drawings indicating a landing light. At the least, there are no leading edge mounted landing lights. Here is a book I came across recently that has a lot of photos of restored Spits. Spitfire Flying Legend. By John Dibbs and Tony Holmes. http://www.amazon.com/exec/obidos/tg/detail/-/1841762105/qid=1091251615/sr=1-1/ref=sr_1_1/002-4273997-9355211?v=glance&s=books I have a hard cover version of the book. Great photos. Sounds like you are going to be passing the point that I am at with my wings. I haven't run the air tubes for the retracts yet, and have not put the top skin on. I've framed the upper fuse and attached the horizontal stab, but not the vertical stab. Been taking a break from the Spit to build a four star 40, do some flying, and work on the house. Scheduling looks like it'll be Sept. before I get back to the Spit in a serious way. When I do skin my wings, I was going to try a technique that I've read about. You use alphatic resin glue. You apply it to all the mating surfaces and let them dry (like you would using a contact cement). Then, lay the skin on the wing and use a cover iron to "reactivate" the glue. It is suppose to provide a very fast and strong bond. It sounded like once the prep is done, you could take time to position the skin, and once in progress you would not have to deal with time constraints that come with CA, or maintaining contact with clamps and weight bags as with normal gluing. I greatly look forward to your progress!! Scott.
