RE: Keith's Top Flite Spitfire build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Keith's Top Flite Spitfire build
Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: Keith's Top Flite Spitfire build - 8/11/2004 3:16:18 AM
tubig
Status: offline
quote:
ORIGINAL: saramos
I have found that Great Planes makes the same style hinge in the small size with a metal pin. I will be using them on my flaps when I get back to my build.
Scott
i believe these are the ones recommended in the tf manual. the robarts are just too big.
(in reply to saramos)
       Post #: 126
RE: Keith's Top Flite Spitfire build - 8/11/2004 9:20:12 AM
squeeguk
Status: offline
I got the ones recommended in the manual. smaller than the Robarts to be used everywhere else.
I will see how many I have and send you some up if you like Keith.
Cheers
_____________________________
Traxxas Revo 3.3 with RB TM523 - Spektrum DX3.0
Hobao Hyper ST Pro - Spektrum DX3.0
(in reply to tubig)
       Post #: 127
RE: Keith's Top Flite Spitfire build - 8/11/2004 12:20:18 PM
CHEF-UK
Status: offline
just ordered the great planes ones anyhow from my LHS should be here in a few days (I hope)
Right, have to go to dentist now, she's so mean
Due to government cutbacks,the light at the end of the tunnel has been switched off!
(in reply to squeeguk)
       Post #: 128
RE: Keith's Top Flite Spitfire build - 11/17/2004 4:34:32 PM
squeeguk
Status: offline
Hey Keith, you still around, haven't fallen off the planet yet? I been waiting with baited breath to check on your progress with no luck. Are you still building?
Let us know where you are in the build process.
Cheers
(in reply to CHEF-UK)
       Post #: 129
RE: Keith's Top Flite Spitfire build - 11/18/2007 12:41:25 PM
jhcorsair
Status: offline
Keith,
When you get to the final construction part of the manual, paragraph 5 tells you to use a #10 drill to drill the holes through the wing bolt blocks and into the fuse wing blocks........DO NOT USE THE #10 DRILL BIT! It's too big! The bit that comes with the great planes 1/4-20 tap kit is a #7. I ended up having to fill the wing block holes with epoxy and re-drilling with the #7 bit. A question to the experts ..........is this a satisfactory repair or should I replace the wing blocks? Feel free to email me with any questions you may have. I'm working on the wing fairings at the moment.
       Post #: 130
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.500RCU4
