LICobra
NY, USA Status: offline
max...it's brand new never flown, unfortunately I bought it on ebay from Hobby-Sports. I took the cowl off and checked out the new brushless motor. Theres no pinion gear, prop shaft or gearbox. It's direct drive, it has a "prop adapter" that slips over the end of the main electric motor shaft and tightens with a allen wrench, although I don't seem to have that size unless its metric ?? maybe the adapter is off a bit, I can't tell if the main shaft is bent because you only see about 1/8 of an inch of the shaft, the rest is the adapter , prop and screw on metal spinner. If I can get the adapter off I can see if the motor shaft is bent, but it does vibrate a bit....pictures in my gallery, havent figured out how to put them in a thread yet.!!! Well it turns out the shaft is ok but the metal adapter with the set screw is not the tightest fit, when parts are available for the BL model I will purchase another adapter. In the mean time I will call parkzone customer service ...
< Message edited by LICobra -- 12/2/2007 3:38:18 PM >
