RE: Extreme Flight YAK 54
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Yak 54 - 68
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> 3D Flying! >> RE: Extreme Flight YAK 54
    Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
    Login
    RE: Extreme Flight YAK 54 - 5/17/2004 4:40:31 AM
    Spaceclam
    Status: offline
    16x6 MAS painted to look like the real yak's prop.
    _____________________________
    Duct tape is like the force. It has a light side, a Dark side, and it holds the universe together.
    (in reply to Constrictor)
           Post #: 101
    RE: Extreme Flight YAK 54 - 5/17/2004 6:27:37 AM
    trailingedge
    Status: offline
    Hey guys keep those pics comin. I'm stuck drooling until I get one in. Is there any chance of mounting the tank on the C/G in this bird???
    Never argue with an idiot. They drag you down to their level then beat you with experience.
    (in reply to Spaceclam)
           Post #: 102
    RE: Extreme Flight YAK 54 - 5/17/2004 7:26:03 AM
    AdrianM
    Status: offline
    Will a Saito 100 on 30% fly this bird? I also have a TT 1.20 Pro Pumped RE engine with Tuned Pipe. I was one was powers with an OS 1.40 was that way over kill on power?
    Adrian Martinez
    (in reply to trailingedge)
           Post #: 103
    RE: Extreme Flight YAK 54 - 5/17/2004 10:18:27 AM
    Matt Merciez
    Status: offline
    quote:
    ORIGINAL: Spaceclam
    ya. I figured out where i wanted to put my servo and it is a very straight shot ffrom there. i have a little hitec micro for throttle. howe am i supposed to mount a quick fueler and a remote glow ignitor on this thing if the fuselage is round? where should i put it?
    With a YS engine you might want to reconsider the quick fueler. I have read several threads here on RCuniverse where they will tend to leak/fail when operating under the pressure from the YS engine. For fueling, I used fuel dots which are very simple and are attached to the cowl.
    I have never used a remote glow ignitor so I can't help there.
    I initially plan on running a 16 x 6 APC prop which is recommended by YS. Chris Hinson was able to run a 17 x 6 apc using 30% heli fuel in his YS. I have a gallon of coolmaster 20/20 to use for break-in of the motor with the 16 x 6 prop. After break-in, I will try a higher nitro content and see if my motor can pull enough rpms for the 17 x 6.
    I will try and add some more pictures this evening of how I have the fuel system setup clam.
    Matt Merciez
           Post #: 104
    RE: Extreme Flight YAK 54 - 5/17/2004 11:04:14 AM
    Matt Merciez
    Status: offline
    quote:
    ORIGINAL: AdrianM
    Not sure about the motors you listed simply because I do not know much about them. Here is some info that might help you in the engine selection.
    The YS 110 will make a bit over 2hp with 20% nitro. (Based on post from the YS tech guys in their forum)
    Here is a quote from Chris Hinson regarding the airframe: "It is designed for an engine in the 26-30 oz range."
    So if you select a motor with at least 2 HP and weigth of 26 - 30 oz, you should have a great flying airframe.
    < Message edited by merciez -- 5/17/2004 7:14:31 AM >
    Matt Merciez
    (in reply to AdrianM)
           Post #: 105
    RE: Extreme Flight YAK 54 - 5/17/2004 11:06:54 AM
    Matt Merciez
    Status: offline
    quote:
    ORIGINAL: trailingedge
    The fuel tank does get mounted fairly close to the CG. The wing tube really prevents mounting the take exactly on the CG but it is close. I will try and post some pictures tonight of how the fuel lines and fuel tank are setup.
    < Message edited by merciez -- 5/17/2004 10:47:52 AM >
    Matt Merciez
           Post #: 106
    RE: Extreme Flight YAK 54 - 5/17/2004 11:10:33 AM
    Matt Merciez
    Status: offline
    quote:
    ORIGINAL: Radcliffe
    Does the kit come with a spinner and if not what size is required ? ( getting a box full of parts waiting for the day that big brown knocks on the door !! ) Thanks Rad
    The kit does NOT come with a spinner. The manual suggests a 3" spinner. I purchased a 2 3/4" tru turn with the lighted backplate. Item number: TT-2752-B-120-L You can see the one picture I posted earlier with the spinner mounted to give you an idea of its appearance. I am happy with the 2 3/4" spinner.
    Matt Merciez
    (in reply to Radcliffe)
           Post #: 107
    RE: Extreme Flight YAK 54 - 5/17/2004 3:05:57 PM
    Spaceclam
    Status: offline
    i am not using the dubro ones. i am using the slimline quick fillers which will not leak. you can mount it on the cowl without it cracking?
    (in reply to Matt Merciez)
           Post #: 108
    RE: Extreme Flight YAK 54 - 5/17/2004 3:28:41 PM
    stomper
    Status: offline
    quote:
    ORIGINAL: Spaceclam
    I think I would glass in a piece of shaped ( round the outside edges to fit inside ) lite ply to the inside of the cowl and just drill a hole though both of them.
    Doug
           Post #: 109
    RE: Extreme Flight YAK 54 - 5/17/2004 9:33:57 PM
    JWilliams
    Status: offline
    Flew mine to day with the YS110, flew awesome! It should be one to keep around.
    Jeff Williams
    (in reply to stomper)
           Post #: 110
    RE: Extreme Flight YAK 54 - 5/18/2004 12:26:12 AM
    Matt Merciez
    Status: offline
    Here are a couple of images of the assembled airframe:
    < Message edited by merciez -- 5/17/2004 7:27:06 PM >
    Matt Merciez
    (in reply to JWilliams)
           Post #: 111
    RE: Extreme Flight YAK 54 - 5/18/2004 12:40:57 AM
    Spaceclam
    Status: offline
    looks familliar! wayne, does it have any coupling in a knife edge? also, what kind and how bad. does it really have a ton of elefator authority compared to other 3d models with such a skinny chord?
           Post #: 112
    RE: Extreme Flight YAK 54 - 5/18/2004 5:01:07 AM
    rc-sport
    Status: offline
    Oops, yes Manteno. I'm plan on being there, a fellow club member is also competing. I'm going to cheer him on.
    (in reply to wgeffon)
           Post #: 113
