HighPlains
KS, USA Status: offline
Hey Bill, It’s not that I don’t like composite airplanes, I just don’t think that they are higher performance than a well designed, carefully built balsa and foam quickie. I find it interesting that people think that they need one to be competitive. They don’t! Are they easier to get into the air – certainly! Are they consistent in performance? Perhaps, though with many of the designs moving to balsa for the core material, you end up with variations in strength, weight, and balance – same as a balsa/foam model. But when you are tied to the composite plane’s designer, you’re not going have an airplane any better, and maybe slightly worse. There are those that have CNC molds for the wings, and that is a plus. But with experience, you can sand about as well since waviness is the critical aspect of most airfoils in the first third of the chord. As far as the ailerons with the flex hinge – the air is completely turbulent by the time you reach that point. So no, it is not important what hinging system you use. It is good to seal the gap line with tape so that the airfoil is not “short circuited”.
